Will these fit my Esc Cos
Old Jul 26, 2009 | 06:14 PM
DAZZER's Avatar
DAZZER
Default Will these fit my Esc Cos
I`m suppossed to be buying some alloys at Fordfair next week but will these fit my esc cos they are Compomotive FR`s 8x16 offset ET28 any advice would be very helpful and also they have group A inserts cheers.
Old Jul 27, 2009 | 09:40 AM
grcossie's Avatar
grcossie
If you use spacers, to get a offset to 25 or lower. They would build to much in, as the oe offset is 25. I use et15 om mine Compomotive, and have also Azev a whit et13
Old Jul 27, 2009 | 05:54 PM
Kelv's Avatar
Kelv
Almost there!
they will sit 3mm further inwards than the standard alloys.
just ensure they clear you brake calipers first.
you are also going to need Grp A conversion wheels nuts unless you have the larger studs, then you will just require the Grp A nuts.
you could use a spacer and space the wheels out back to the origonal et25 for the 8x16" wheel, but 3mm is hardly worth loosing a great deal of sleep over if they fit and clear the brakes.
Old Jul 29, 2009 | 06:14 PM
alo's Avatar
alo
I was running compomotive th's earlier this year et28 16x8j and they fitted really well until i put big brakes on. Now I have focus rs brembos and disc's and I need 17" at least
Carlbacciochi
24
Jun 30, 2016 04:31 PM
y4n
Aug 17, 2015 12:12 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
cameron2
Aug 10, 2015 12:14 PM
ray barker
Aug 7, 2015 09:00 AM
