cosworth fuel pressure regulator?
Old Dec 15, 2004 | 04:14 PM
Paddy rst's Avatar
Paddy rst
Default cosworth fuel pressure regulator?
whats the difference between a 2wd and 4wd cosworth fuel pressure regulator??
also when using the efi fuel rail when converting a rsturbo to cos management what regulator is recommended/fits the efi fuel rail??
Old Dec 15, 2004 | 04:45 PM
Stu @ M Developments's Avatar
PassionFords Creator
4x4 cossie is o ring fit, 2wd is std pipe fitment.
Just use the EFI reg with the EFI rail
Old Dec 15, 2004 | 04:49 PM
Paddy rst's Avatar
Paddy rst
cheers stu m8.
jc1989rs
Aug 30, 2015 06:32 AM
Prickly_buzz
Aug 25, 2015 11:33 AM
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
