NEED HELP AGAIN" rs wont strat :-(
Old Jul 23, 2009 | 08:00 PM
RSTurboSI's Avatar
RSTurboSI
Default NEED HELP AGAIN" rs wont strat :-(
well, got a new battery today, fitted it started the car and it ran..
turned it off and then went inside. tryed to fire it up and wont run.
we put some fuel init just incase, whats happened it that the fuel pump is priming, but when we stop trying to fire it up the pump makes a sound like its grinding, asin empty, could this be my problem? and anything else to check, otherthan getting aload more fuel init because were not sure on the reading. also its a brand new battery, well thats gone dead :S we can do any reading or testing on the alternator
we have spark, we can smell fuel inside the engine bay. it started when the battery was connected as said but now it wont fire up.. god this car is doing my head in LOL
Help please people
Old Jul 23, 2009 | 08:10 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
fuel pump relay?
Old Jul 23, 2009 | 08:12 PM
RSTurboSI's Avatar
RSTurboSI
that's new.. again it worked first time and second time of running the car, then left it while i rang my insurance to start the policy and then wopps wont start.
Old Jul 23, 2009 | 08:23 PM
antony215's Avatar
antony215
Escort Rs Turbo
Is it turning over?
Old Jul 23, 2009 | 08:28 PM
RSTurboSI's Avatar
RSTurboSI
yep its turning over, just not fireing up anymore.
Old Jul 23, 2009 | 09:06 PM
project rs's Avatar
project rs
take air filter of and check that metering unit flap is bouncing when your trying to start and get an assistant to depress it a tiny amount to see if that helps
Old Jul 23, 2009 | 09:22 PM
ricky_2006's Avatar
ricky_2006
ignition coil
Old Jul 23, 2009 | 10:35 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
sounds like your fuel pressure is low and pump is dying.
you'll get fuel but it will run down ports and not mist like it should.
Old Jul 24, 2009 | 07:38 AM
RSTurboSI's Avatar
RSTurboSI
but it started before, just not the 3rd time, i ran for 10-15min so not sure will get some fuel init later today and go from there
Old Jul 24, 2009 | 11:42 PM
jodyhoare's Avatar
jodyhoare
ok i think i know ur prob mate, if it ran out of fuel they often get air locks in the fuel system, try undoing 1 of the banjoo bolts on the metering head then while someone holds the fuel pump realy on, you hold the flap on the metering head down till fuel comes out. do this with all 4 of the bolts then give it a go m8.
hope this helps
CosworthGuy
Aug 25, 2012 11:55 AM
coolj
Ford Mondeo Including ST
Feb 21, 2012 08:02 PM
mr noisy
40
Jan 19, 2012 10:12 AM
lockie
Dec 2, 2011 09:32 PM
SapphyMike
Apr 25, 2007 09:52 PM
