monoblock cossie
Old Dec 15, 2004 | 03:46 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Default monoblock cossie
something karl just posted just reminded me of a thought i had a couple of nights ago.
back in the days of turbo'ed f1 cars, they used to run monoblock engines where effectively the 'head' and 'block' are all one piece. the advantage being that there is no gasket to blow out.
due to advances in casting and machining technology and prototyping techniques, i wonder if it must now be possible to create a monoblock engine that could, for example, be fitted with yb components like crank, rods, pistons, camshafts, valve gear etc.
the advantage would be a reliable engine capable of higher dynamic pressure ratio's (either a higher static c/r, or more boost) for a longer time than the normal engine.
cost would probably be massive, and i don't know if it would be possible to install normal valves in the confined space or whatever.
that's just a few of my thoughts. anyone else got any on this subject? is it impossible, impractical, or just too expensive?
Old Dec 15, 2004 | 03:52 PM
Too expensive, and to be honest, if you are going to start doing that sort of thing you would be better off building a decent rotary motor instead!
Old Dec 15, 2004 | 03:56 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Down at Bluesprint they got fookin loads of Monoblock F1 engines etc and ive had a good look at em.
All i can say is fook working on them, bloody nightmare
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
