Measuring cam lift.
Old Dec 15, 2004 | 03:15 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Measuring cam lift.
How do you?
Just been going thru lots of junk and just wanted to make sure the cams i got are std before i sell em, as i remember the bloke reckoned they wernt, but everyone tries that bollocks...
Old Dec 15, 2004 | 03:20 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you need to measure the radius of the largest part of the 'egg' and the radius of the smallest part. the lift is the difference between the 2. it's actually much easier to do with the cam in situ using a dial gauge or something.
Stu @ M Developments's Avatar
PassionFords Creator
DTI on closed valve, set it to zero, then rotate the cam until a max reading is shown on dti. That is peak lift.
To measure duration, use the same tool but also a protractor on the crank, and measure how many degrees the dti indicates any form of valve lift for...
Old Dec 15, 2004 | 03:21 PM
Afternoon Nick
Old Dec 15, 2004 | 03:22 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Cant do it on the car as they not been on the car for months, lol
Old Dec 15, 2004 | 03:38 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Right, as im a thicko and think of better words to use right now, bear with me...
I need to measure the big bit/lobe height compared to the normal lobe height (ie the bit underneath the big bit/lobe)?
No? Eh?
Old Dec 15, 2004 | 03:48 PM
foreigneRS's Avatar
foreigneRS
Testing the future
evening stu (time to go home now, i need to get me a pizza)
steve, that's what i said didn't i?
Old Dec 15, 2004 | 03:52 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
I thought you said that, but i wasnt sure
I am now, thankyou kindly
Old Dec 15, 2004 | 06:29 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Right, gone round a mates and robbed his snazzy electronic digital measuring calipers to do the lift
Any way of measuring duration without it being in the head and using a dti?
My mate started doing diagrams of cam lobes and triangles n shit so i just left as i didnt have a clue
tankybaby66
Feb 6, 2016 02:24 PM
Mikersturbo
Sep 27, 2015 07:43 PM
