Geometry People FWD car
Old Jul 22, 2009 | 01:37 PM
Spiky's Avatar
Spiky
Default Geometry People FWD car
ok,
one thing i have never really done is have then Pug setup right, mainly becuase i wasnt 100% sure on the settings it should have
currently (monday it was done) i had the tracking setup from 3.5 degrees toe IN to 2 degrees tow OUT
will find out next week how that it is, but it was a bit understeer city, so i think it will be much better
but what i want to know is what settigns should i be ruuning?
Toe ?
camber ?
castor ?
anyone know? or have a roughly right figure?
Old Jul 22, 2009 | 01:42 PM
xr-stu's Avatar
xr-stu
im sure someone will come along and correct me but fuck it, iirc, toe has a bearing on stability at speed and the turn in response, so is down to person preference more than anything. camber should be at around 1.5-2.0 degrees as a standard ballpark. and i know little about castor but i was under the impression the more the better.
Old Jul 22, 2009 | 01:47 PM
Spiky's Avatar
Spiky
yeah 2 degree neg camber was something i had flying around in my head
i dont know what castor brings to the game?
i will try my new camber setting and see how i get on
but thanks for the info
Old Jul 22, 2009 | 01:52 PM
Porkie's Avatar
Porkie
Jesus Spikey! I thought by how fast your little car went that all this stuff had been optimised already!!!
by the amount of fast track and race 205's out there someone must know THE exact best settings for each kinda different track and style of driving and tyre etc etc...
dig a bit harder or ask else where mate
alistairolsen's Avatar
alistairolsen
caster brings steering feel and weight, and gives you more camber as you turn the wheel more. Think go karts.
On a strict track car running radial tyres Id go for:
1mm toe out
1.5 deg neg camber
4-6 degrees of castor depending on what you can achieve by modifying bits to pull the top of the strut back, or the bottom balljoint forwards
on the rear you might want to shim the axle where the stub axles bolt on to try and get 0.5mm toe in per side, 2 degrees neg camber
Old Jul 22, 2009 | 01:54 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I agree totally with Ali Olsen, thats exactly the same numbers that I would have said based on my experience with other FWD cars, possibly even a little more castor though, as much as 8 even would be a good thing.
I often run parellel though on the toe, even though slight toe out is probably better, I just prefer the slightly less "alive" feel to it when parellel, but you might find the opposite and want to go +2mm of course, its all about pesonal preference, no right or wrong answer, but Ali has certainly stated a good ballpark
Old Jul 22, 2009 | 02:02 PM
Luca's Avatar
Luca
Lukesville
You need to give these guys a call mate...
http://www.balancemotorsport.co.uk/m...ry=Project+Car
Old Jul 22, 2009 | 02:03 PM
alistairolsen
I wouldnt want to go as far as 8 on track tyres and a manual rack tbh.
You may also find you run into issues with driveshafts fouling and stuff, my knowledge is vauxhall specific, but novas you can only get about 6.
Old Jul 22, 2009 | 02:06 PM
Chip's Avatar
Chip
Spikey only runs 195's so I dont think 8 would make it too heavy, you're right though that he will probably hit a mechanical limiting factor before he gets to that anyway so its quite likely to be acedemic!
Old Jul 22, 2009 | 02:08 PM
Spiky's Avatar
Spiky
cheers guys the 205 forum is full of my way is best based on what they think.
Porkie. My car has never been setup lol. Always use the eye pmsl.
Will do the track day next week and go from there then and use the advice above
Old Jul 22, 2009 | 02:11 PM
Chip's Avatar
Chip
Spikey are you on 309 front wishbones?
Cause if so they add a bit of castor IIRC and not just camber
Old Jul 22, 2009 | 02:14 PM
Spiky's Avatar
Spiky
yeah 309. Cant see how they would alter castor. As they are only 7mm longer. Outwards
Old Jul 22, 2009 | 02:17 PM
Chip's Avatar
Chip
Apparently they sit the wheel very slightly further forward as well as further out
Old Jul 22, 2009 | 02:20 PM
alistairolsen
Spiky, do you run eccentric topmounts? If so, have a look and see how far back you can get the top of the strut to sit. Should be an hours work max, redo the tracking and then do the trackday, soon tell you if you like it or not.
Old Jul 22, 2009 | 02:21 PM
Chip's Avatar
Chip
I bet even his max setting is still not really as much as he wants!
Old Jul 22, 2009 | 02:24 PM
alistairolsen
no, but its quick and easy and a good start, and the 205 isnt as easy as the nova for moving the bottom, so after this comes cutting the strut tops and more serious (winter) surgery.
Old Jul 22, 2009 | 02:26 PM
Chip's Avatar
Chip
I agree thats its a good start mate, I was saying not to do it cause it wont be enough, quite the opposite in fact the reason it wont be enough still is the reason that it will definately be better than any other position he can run it in on his current hardware.
Old Jul 22, 2009 | 02:47 PM
It's Czech Mate's Avatar
It's Czech Mate
I'd go for a toe of 0 degrees......as once on the move the deflection of the bushes will give it a bit of toe out, unless it's rose jointed already?
Old Jul 22, 2009 | 02:51 PM
alistairolsen
Id guess its on polybushes, and tbh they wont deflect enough to cause that. Id be starting at between 1 and 2mm (from a known figure) and having a play back and forth from there.
Old Jul 22, 2009 | 04:24 PM
Spiky's Avatar
Spiky
ok few questions there..lol
i have eccentric top mounts
pretty much to most camber like below
i did have RJ's ADJ TCA's but they fouled a few areas and was, un safe, so removed them and fitted STD 309 wishbones, though i'm in the process if putting a RJ on the std wishbone and will polybush the inner mounts
i dont think there is much room to move the eccentric mounts back on the 205, as you can see from the pic
really appreciate the comments though
Old Jul 22, 2009 | 04:26 PM
Chip's Avatar
Chip
Id move it back further spikey, even though you will lose a little camber
Old Jul 22, 2009 | 04:29 PM
Spiky's Avatar
Spiky
ok after next week,
i'm taking the front struts off to get them shortened, and will get the new ADJ wishbones put on and run maybe more castor on the top mounts and get more neg camber from then adj wishbones while lowering it a bit too
Old Jul 22, 2009 | 04:31 PM
Chip's Avatar
Chip
Cool, if you can get enough camber on the wishbones alone then put it in the fully back position on the top mount, if not put it midway between the fully back and the fully cambered positions.
Careful of driveshafts if making the wishbone too long of course mate, although on a lowered car its not normally an issue
Old Jul 22, 2009 | 05:31 PM
Spiky's Avatar
Spiky
i have 405 drive shafts as spare for that very reason, they are 10-15mm longer than the 309 drive shafts i'm currently using
Old Jul 22, 2009 | 05:38 PM
jammerrs's Avatar
jammerrs
let us know how you get on useing the setting you use, be interesting to find out the results,
i thought castor only gave a slight improvement in straight line stability but dift cars use it becuase it makes the steering easier to get from one lock to the other
ow well learn something new everyday
Old Jul 22, 2009 | 05:39 PM
Spiky's Avatar
Spiky
i'll report back next week
Old Jul 22, 2009 | 05:44 PM
Cawood's Avatar
Cawood
i need to find out something similar (sorry for the thread hi-jack spiky)
taking my RST for setting up next week, (fitted MEF's adj TCA's)
what am i best going for toe, camber and castor?
mines only a road car tho,
think martin give me some set up info ages ago regarding this, but i've only just managed to find somewhere that can set them up for me!
Old Jul 22, 2009 | 06:34 PM
pee vee's Avatar
pee vee
give either, x sport a ring
or neil garner mate
he is not too far from combe.
http://www.neilgarner.co.uk/
Old Jul 22, 2009 | 08:00 PM
Spiky's Avatar
Spiky
ok will wait until my new suspension setup is done, then sort it iut
hopefully it will corner better too
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
Kevin_Mc
Aug 6, 2015 07:47 PM
