AFR Gauge on std lambda sensor
Old Dec 15, 2004 | 01:04 PM
Jim Galbally's Avatar
Jim Galbally
Default AFR Gauge on std lambda sensor
can you pipe into the signal wire from the std lambda sensor on the car for an AFR gauge without affecting the readingings being given to the ECU?
Old Dec 15, 2004 | 01:07 PM
zvhturbo's Avatar
zvhturbo
I should think so, its only reading the signal voltage.
Old Dec 15, 2004 | 01:09 PM
Hofajoab's Avatar
Hofajoab
i would have thought so as well but i think it's a really low voltage 0v - 1v ? ... the AFR guage would probably have a buffer in it anyway if it was going to affect the reading.
Old Dec 15, 2004 | 01:24 PM
Utter crap.
Dont bother, narrow band sensors are useless.
Get a decent wideband setup instead.
Old Dec 15, 2004 | 04:05 PM
Jim Galbally
dont worry chip i'm just borrowing one, and its only so i know when the closed loop stuffs working, not for tuning etc.
Old Dec 15, 2004 | 04:08 PM
flashpoint's Avatar
flashpoint
Hi Jim, Go wideband Don’t waste you money messing about with the standard narrow band, as they are not that accurate, invest in a wideband setup.
Steve
Old Dec 15, 2004 | 04:28 PM
For checking the closed loop is functioning it will be fine.
In fact it will be better for that than a wideband, as if the lamda sensor is reading wrong for any reason then both the gauge and ecu will see the same wrong values so should still concur.
Old Dec 15, 2004 | 05:17 PM
EscortWRC's Avatar
EscortWRC
Narrow band sensors with displays are just a bunch of pretty lights
They are completely useless
Old Dec 15, 2004 | 05:29 PM
XRTypeRS's Avatar
XRTypeRS
Steve
Agreed!!!!
Old Dec 15, 2004 | 05:31 PM
tiny's Avatar
tiny
Y are they crap. and what is the difference between wide band. narrow band
Old Dec 15, 2004 | 05:35 PM
EscortWRC's Avatar
EscortWRC
Narrow band sensors are only 'accurate' between about 14.3: 1 and 15.0:1 and most cars with turbos run considerably richer than 14.3:1 on boost, so it would just indicate RICH most of the time, but not tell you HOW rich.
Wide band has a different voltage range and is accurate from about 7.0:1 to around 35.0:1 and will actually provide you with useful information.
Old Dec 15, 2004 | 05:44 PM
tiny's Avatar
tiny
Thanks would narrow band be ok 4 na engine,
Old Dec 15, 2004 | 05:48 PM
EscortWRC's Avatar
EscortWRC
No, narrow band is useless
Old Dec 15, 2004 | 05:50 PM
Narrow band is pointless for anything other than checking that an ecu tracks around it properly, but as thats what he says (for some weird reason, lol) he wants to do, it will work for that.
Old Dec 15, 2004 | 06:08 PM
tiny's Avatar
tiny
So it wont accuratley tell me weather or not my carbs are running to rich
or to lean, iwas going to use 2 aftermarket ones wired into 2 autometer
gauges.One for each bank of carbs on a v8. thanks
Old Dec 15, 2004 | 06:28 PM
Jim Galbally
chip... i want to know what the fueling's like (economy wise) etc.
since mine is closed loop it SHOULD always read stoich on cruise...
if it don't... then i need to use less throttle or less revs... tis just an indicator as to if i'm driving too hard or not i s'pose..
anywa, i can borrow this gauge for a while so don't see why i shouldnt bother... lol
Old Dec 15, 2004 | 06:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
or to lean
it will accurately tell you if you are rich or lean, but it won't tell you accurately how rich or lean if you get me.
Old Dec 15, 2004 | 06:54 PM
tiny's Avatar
tiny
So do i just need to buy a wide band lambda sensor and wire it to theautometer gauges, sorry i am a bit thick.
Old Dec 15, 2004 | 07:14 PM
foreigneRS's Avatar
foreigneRS
Testing the future
no, that will bugger it up immediately.
wb sensors need a controller and stuff. do a search on here or google for wide band stuff. there's plenty of info out there. techedge for example.
Old Dec 15, 2004 | 07:34 PM
tiny's Avatar
tiny
Thanks
Old Dec 15, 2004 | 08:48 PM
ive got a techedge one, nice bit of kit.
Old Dec 15, 2004 | 10:33 PM
flashpoint's Avatar
flashpoint
I to use techedge wideband,
Steve
Old Dec 15, 2004 | 11:03 PM
Thats the same display ive got in my nova, ace little bit of kit
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
20/20 vision
Sep 29, 2015 09:25 PM
