Crossflow Engine Trouble
Old Jul 20, 2009 | 12:52 PM
Dave_mk2's Avatar
Dave_mk2
Default Crossflow Engine Trouble
Hi
I have a 1360 xflow in my kit car and it has developed a rattle like the sound of a ka on the overrun. I have changed the big end shells but its not helped. The oil pressure is fine no smoke from the exhuast and performance hasnt been effected.
Any ideas what could cause this?
Old Jul 20, 2009 | 03:59 PM
Icurus's Avatar
Icurus
small end bearing?
Old Jul 20, 2009 | 06:23 PM
105epwr's Avatar
105epwr
have you checked the valve clearances?
Old Jul 21, 2009 | 01:04 PM
Dave_mk2's Avatar
Dave_mk2
Would'nt the small end bearings make noise on tickover? As this noise is only coming on overrun.
Valve clearance is fine.
Old Jul 21, 2009 | 01:06 PM
steveboyslim's Avatar
steveboyslim
Timming chain ?
Steve
Old Jul 21, 2009 | 03:14 PM
whosyadaddy's Avatar
whosyadaddy
have you removed a rocker arm to check they aren't worn where the top of the valve stem meets the arm, if this is worn this can cause the symptoms you described.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
Ben26
Aug 27, 2015 08:56 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
