Escort Cosworth ABS ECU Lcoation Help
Old Jul 20, 2009 | 08:13 AM
daviddunlop83's Avatar
daviddunlop83
Default Escort Cosworth ABS ECU Lcoation Help
The car is in the auto electricians at the min and he just rang asking where the ABS ECU is located on a 1996 escort cosworth
Can anyone tell me where it is?
Thanks
Old Jul 20, 2009 | 08:15 AM
CRAIG HAYTER's Avatar
CRAIG HAYTER
is it not at the passenger foot well on the left hand side i know the ecu is there would imagine thats also there
Old Jul 20, 2009 | 08:17 AM
daviddunlop83
I know the engine management one is there but im not sure if the ABS one is there also?
Turbosystems's Avatar
Turbosystems
Super Moderator
it's in the boot N/S rear quater
CRAIG HAYTER
looks like turbosystems got it
Old Jul 20, 2009 | 08:20 AM
daviddunlop83
Old Jul 20, 2009 | 08:21 AM
daviddunlop83
Also would anyone know where to get a wiring diagram for the ABS system?
Old Jul 20, 2009 | 08:24 AM
Turbosystems
Super Moderator
a good auto electrician
Old Jul 20, 2009 | 08:25 AM
Turbosystems
Super Moderator
the escort cosworth abs has fault diagnostics unlike the sapphs
get it read
if you post up your problem you'll probably find the pf clan will fix the fault
Old Jul 20, 2009 | 08:29 AM
daviddunlop83
get it read
What software do you need to be able to read the fault and where is the diagnostics port for it?
The auto electrican said he cant get a wiring diagrame anywhere but he will sort it anyway. He said the pump isnt getting power at all tho.
Old Jul 20, 2009 | 08:32 AM
Turbosystems
Super Moderator
the pump system has it's own power supply in fact it has 2 for safety, so the pump will work even if you stick the ecu in the toilet
Old Jul 20, 2009 | 08:35 AM
daviddunlop83
Both of the power supplys arent working then lol.
Can ford still use the diagnostics for the escort cosworth? I know the only dealer here who had the old break out box for the sierra sent it back to dagenham a long time ago he said. He said best they could do for the sierra was one of those flashing led reader things
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
