Original A/C on 3dr Cossie??
Old Jul 19, 2009 | 02:10 PM
Thanasis's Avatar
Thanasis
Default Original A/C on 3dr Cossie??
hello,i would like to ask if the 3dr sierra cosworth's had geniune air-condition from factory,thanks a lot
Old Jul 19, 2009 | 04:18 PM
Mike1's Avatar
Mike1
I've heard of aircon on Sapphire 4x4s but not factory fit on a 3-door or early 2wd Sapphire ( I prepare to be corrected ).
I know they did aircon on XR4is and XR4x4s though so it might be a possibility it was a dealer fit or factory order on a 3-door at the time.
The Sapphire aircon cars have different holes in the bulkhead though
Old Jul 19, 2009 | 05:35 PM
Ive never heard of it on a 3dr cossie either.
Old Jul 19, 2009 | 07:41 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
My saph had aircon fitted at the dealership.
Steve
Old Jul 19, 2009 | 08:17 PM
DD's Avatar
DD
No mate was never fitted on a 3dr from the factory. I looked at doing this some time ago to my 3dr, and even bought all the AC parts (of which i still have), but having looked into deeper, it meant changing part of the bulkhead to house the Sierra XR4x4 condensor/fan assy i think?, and i just thought it wasn't worth it...although would make a top mod...
DD
Old Jul 21, 2009 | 02:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there is quite a substantial amount of bulkhead that needs "fettling" to get the gubbins to fit in for starters
but if you can find a bulkhead with the neccesary big lump in it it's possible to cut it out and fit it to your car, the granada's are more likely to have it than the sierra's, the lump is the same shape as are the hole positions
all the one's i've heard of that were fitted to the pre 87 spec 3 door cars of both cossie and 4i variety were all retro dealer fit jobbies
when they did the facelift and got the saph then a/c was an option
don't discount the early xr4x4's, these were the 5 door versions that did have factory a/c as an option, totaly different to dealer fit
Old Jul 22, 2009 | 07:11 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the condenser is the radiator looking bit at the front. the interior heat exchanger is the evaporator
Old Jul 22, 2009 | 08:44 PM
dojj's Avatar
dojj
this shows you just how much more space you need, the fan on the normal set up is right next to the bulkhead, so you can see you need a big bit of bulkhead removed to fit the big box for the evaporator
Old Jul 23, 2009 | 07:51 AM
Alpinair did some as oe fit, for ford.
Old Jul 23, 2009 | 11:14 AM
DD's Avatar
DD
that's the thing, bloomin great thing to house... i have all the bits to do it, but didn't have the heart in the end.
Old Jul 23, 2009 | 11:24 AM
R4N SS's Avatar
R4N SS
i have a spare 3dr cossie bulkhead if anyone needs it
Old Jul 23, 2009 | 12:13 PM
dojj's Avatar
dojj
the thing is mate, you need the aic con bulkhead to chop out the bit that the air con lump of plastic sits in that houses the evaporator
the thing is probably 50% larger than your heater matrix and so the box it goes in is that much bigger as well, plus it's got the recycle gubbins fitted to the inside as well which complicates matters a bit more
i'll see if i can get a pic of one from the garage if i've still got it but it's a great big lump of a thing that only pictures will fully properly explain
Old Jul 23, 2009 | 05:07 PM
liammcl's Avatar
liammcl
These might help
These are from a XR4x4 with aircon
Old Jul 23, 2009 | 09:00 PM
dojj's Avatar
dojj
thems the pics i was looking for fella
someone else posted them years and years ago on another site but they've been photobucketed to red crosses
Old Jul 24, 2009 | 06:39 AM
liammcl's Avatar
liammcl
I'll dig the box out if i've still got it and take a photo
Sierrasideways
Oct 8, 2015 06:37 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Thanasis
Sep 7, 2015 07:33 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
