Faulty map sensor ?
Old Jul 16, 2009 | 12:43 PM
jemis's Avatar
jemis
Default Faulty map sensor ?
Can a faulty map sensor cause overfuelling on tickover. Other sensors have already been changed ect, act etc.
Old Jul 16, 2009 | 02:21 PM
Yura's Avatar
Yura
I think it can. check it voltage at ECU side at idle. do you use lamda? how do you know about overfueling?
Old Jul 16, 2009 | 02:29 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
After installing a used map sensor I couldnt adjust the co reading at idle below 8%. After buying a new one it solved this problem.
Old Jul 16, 2009 | 02:51 PM
jemis's Avatar
jemis
what did it run like any black smoke
Old Jul 16, 2009 | 03:15 PM
Sonic Boom's Avatar
Sonic Boom
When the map sensor went on my 3 door it drove awful off boost and spluttered on idle when you gave it some beans it was fine, it was the map sensor telling the ECU it was in boost all the time and bunging in loads of fuel constantly, loads of black smoke as well.
Changed the map sensor and it was fine.
Rich
Old Jul 16, 2009 | 03:38 PM
jemis's Avatar
jemis
Rich
That sounds like the symptoms I'm getting, bad idle cutting out etc clears at higher revs and black smoke on idle.
Looks like a new 3 bar map sensor needed then.
Thanks for the input.
Old Jul 17, 2009 | 08:49 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
No, when driving it was too lean, but that was due a bad chip. The idle problem was a bad map sensor.
'Nice' to have these two defects at the same time... Time consuming but solved in the end!
Good luck.
Old Jul 17, 2009 | 05:10 PM
jemis's Avatar
jemis
Got a new map sensor this mourning from Jacko at Blue Oval, fitted it this afternoon and problem sorted now running as it should.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
