Rev counter on td engine..
I've fitted GTI clocks (MK6) to my van. Any ideas which pin in back of clocks is for Rev counter? and can You wire it using Ve signal on Diesel altenator??
Thanks
Thanks
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
what years is the van?
ive got a 97, i fed a wire from pin 13 of the ecu to i believe its pin 8 (blue plug, it may be empty) on the back of the clocks, works fine.
pm me for any more details
good luck
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
