Anyone flushed their heater matrix before??
Old Jul 8, 2009 | 06:33 PM
JokerDisco's Avatar
JokerDisco
Default Anyone flushed their heater matrix before??
Thinking of flushing out the heater matrix in series 2, blowers only blow cold air! Tried everything else so thought it might be worth giving it a go before replacing the matrix! Anyone one done this? Thinking of just whacking a bit of cillit bang through the matrix and then blasting it through with the hosepipe! Wot you reckon??
Old Jul 8, 2009 | 07:21 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
blow ya pressure washer thru it, but be warned, if its to blocked,it might leak!
Old Jul 9, 2009 | 03:38 PM
mark2's Avatar
mark2
hi fella
could be the little plastic ball in the thermo housing do a search on here and you will find a few post about it
mark2
Old Jul 9, 2009 | 04:02 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Seems like alot of agro for something that probably won't make much difference! If I had gone to the agro of removing it, I'd almost definately replace it.
Old Jul 9, 2009 | 04:17 PM
orion_crazy_carl
orion=mini saff
U can flush it with it in the car
Old Jul 9, 2009 | 08:03 PM
JokerDisco's Avatar
JokerDisco
Originally Posted by mark2
hi fella
mark2
Replaced the thermostat with a lower operating temperature - no change
Its still in the car, thought I'd give it a go as its hassle to remove the dash etc. A mate did it to his Mk5 Escort and it worked a treat!! Thought it may be worth a go just to see if it works.
Yeh thats what I'm going to do before it ends up coming out!!
Thanks for the replys anyway!!1
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
