oil out my dump valve
Old Jul 8, 2009 | 10:46 AM
RS CR41G's Avatar
RS CR41G
Default oil out my dump valve
hi,just lately ive been having oil cuming out my dump valve.it did it a while back so i fitted a oil catch tank then it was all fine no oil or any thing.but no its started doing it again.theres oil in the metering unit under the air filter,the bottom end is all rebuild its had valve stem seals put in,gota get it sorted cause ford fair is very soon! any help would be great thanks
Old Jul 8, 2009 | 12:52 PM
RS CR41G's Avatar
RS CR41G
ive been told its best to run the oil catch tank to the atmosphere is this true?its a brand new turbo technics turbo aswel because my mate said its the turbo seals have gone but carnt be if brand new! still any help woulb be great thanks!
Old Jul 8, 2009 | 02:25 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
i used to have the same problem...oil from the dump valve when i was pushing the car. Then i fitted an oil catch tank and now isn't there any sign of oil...But i vented the fumes to the atmosphere. My filter is like new now after 1500km
Old Jul 8, 2009 | 05:29 PM
RS CR41G's Avatar
RS CR41G
thanks for the reply mate! it looks like ill have to vent the fumes to the atmosphere! going to do compression test in abit just to make sure.cheeRS mate
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
RS-Rikki
Sep 21, 2015 07:27 AM
coscor86
Sep 20, 2015 01:21 PM
rs_jim
Sep 19, 2015 08:41 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
