finally plumbed my boost gauge in and im running a wopping
.......0.5 bar
or 6psi
i think somthing is definatly wrong...actuator/bad set up/
does some times smell fuelly, but it doesnt to badly on fuel
i think cosworth were set at 10psi? does this mean im running 180bhp
or 6psii think somthing is definatly wrong...actuator/bad set up/
the cars engine is standard, i might take the ECU out and see if the chip has been changed, its goes well for 0.5 bar though
squats on boost in 1st/2nd gear
thanks for your advice tony
You too Tony, when you pulled in to the meet your cars presence was immence - i was glad i was leaning on my car...
Right so my car is stage one but the boost gauge is showing 6psi
will keep this thread posted
i havent done so yet martin
the bloody thinkg doesnt want to start now, got a feeling its somthing to do with me taking ECU out
it was cranking when i was trying to start it this morning but then it just wont do now not clicking or anything, even with me getting it jump started
lol tabetha
well somthings happened
dont know if the alarm has tripped a shutdown mode or if i have stuffed the ecu when taking it out to see the chip
fuel pump does not prime but power is going to the ign amp, coil etc
alarm is a cobra 7925
Making sure the ecu plug is pushed fully home would be my first port of call!
As for the boost, do you still have a standard plastic dumpvalve? There was one on my car when i got it, it was leaking like a fucked fridge and loosing me loads of boost
Check that and check all the hose are on and you have no airleaks. After that look at adjusting the actuator.
To be honest i'd probably change that chip to one from a know good company and set the car up the way they advise, that would be the safest route!
Check that and check all the hose are on and you have no airleaks. After that look at adjusting the actuator.To be honest i'd probably change that chip to one from a know good company and set the car up the way they advise, that would be the safest route!
gchristophi
Aug 31, 2015 10:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Nice to meet you at last mate
