wots the diffence between lsd and atb
Old Jul 6, 2009 | 05:36 AM
sean2k's Avatar
sean2k
Default wots the diffence between lsd and atb
hi all i ave heard so much bwt lsd and atb and wot do they do and wot does the names stand 4
Old Jul 6, 2009 | 05:43 AM
R5FORD's Avatar
R5FORD
ATB- Automatic torque biasing..
If one wheel is spinning more than the other the diff transfers power to the other wheel to get even wheel spin IIRC
Old Jul 6, 2009 | 07:03 AM
WongRS's Avatar
WongRS
an LSD i susually a plated diff, very little give, good in RWD, a bit odd in FWD.
ATB isn't so harsh, as R5FORD, the ATB transfers the power to where its need, not so good n RWd but nice in FWD.
This is as far as i'm aware and not gospel!
Old Jul 6, 2009 | 07:10 AM
R5FORD's Avatar
R5FORD
I think ATB is no good if your planning on going airborne
Old Jul 6, 2009 | 07:21 AM
GavStyli's Avatar
GavStyli
Kasapis
atb is great for cornering in a fwd, tricky keeping it in a straight line tho!
Old Jul 6, 2009 | 11:57 AM
sean2k's Avatar
sean2k
thanks guys been reading pf and ff 4 a year and hadnt had a clue wot it ment
Old Jul 6, 2009 | 12:48 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Limited Slip Differential
Automatic Torque Bias
from memory
the atb that quife use is a purly mechanical device whereas most common lsd's use plates of fluids inside them to progrevisly lock up
Old Jul 6, 2009 | 04:52 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Should of bought last months fast ford (the one with the series1 thrash), was a good feature on all the differnt types of Diffs!
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
mark r
Sep 29, 2015 07:27 PM
`spotty
Sep 25, 2015 11:41 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
