s2 cabby turning getting fuel,spark but wont fire
Old Jul 5, 2009 | 11:43 AM
safcdixon's Avatar
safcdixon
SAFCDIXON
Default s2 cabby turning getting fuel,spark but wont fire
any ideas poeple cheers
Old Jul 5, 2009 | 11:54 AM
studabear's Avatar
studabear
compression? correct firing order? timing correct?
anymore details, has it just broke down or has it been in bits??
Old Jul 5, 2009 | 12:32 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
firing order i belive is correct ive checked the timing a thousand times i aint got a compression tester but when turning the car over by hand i feels like it has plenty but ive just took the rocker cover off and turned it over no oil to the top end at all i did the sump a few months ago and forgot to put the pickup tube back on then found it when id finished took it apart again and put it back in but couldnt find the one ov the bolts could this be a problum im hopeing this aint the pump cos that would be the end for the cab or and the last time i drove it the turbo werent working at all not spooling nothing
The Underdog
29
Sep 7, 2015 09:49 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
