efi flywheel ? cps?
Old Jul 5, 2009 | 11:34 AM
B1G_RST's Avatar
B1G_RST
Default efi flywheel ? cps?
dont no what im going to be doing in a month work wise so the gotech is in hold for time being,
i have a full FRST efi ofab setup in my garage and a set of 308cc injectors thinking of just keeping this stuff and fitting it,
when i rebuilt my engine i used a non 90spec bottom end so i dont have the cps hole, but i did fit a efi flywheel, so im going to drill me block in situation, which i should be able to do?
anyway the flywheel can only go on one way correct? ie i canot have fitted the flywheel one bolt infront ect so when my engine is a TDC the cps will be in the correct postion, sorry im not making it very easy to understand lol,
also i have a late 90spec block with the cps hole, so i can take measurements of this, but if i drilled the hole 1-2mm out will the cps still get a reading?
thanks for any info giving
sean
Old Jul 5, 2009 | 11:55 AM
studabear's Avatar
studabear
from what I've read in the past it will need to be pefectly positioned
Old Jul 5, 2009 | 01:00 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
+1 i think you may fined it hard drilling it with the engine in place. yes you can only put the flywheel on ne way
DixieTheKid
11
Jun 6, 2020 11:20 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
