braking problem, the story continues
Old Jul 2, 2009 | 06:44 PM
Gregor's Avatar
Gregor
Default braking problem, the story continues
Hejj alll,
Finally got my Zetec Turbo up and running so been driving around a bit.
Next problem is the braking issues it's stil having.
Problem when the zvh was in it was it was braking good at one moment and the other moment like the brake assist isn't working.
Now the thing is it feels like it has no brake assist all the time.
When i hit the brakes with the engine off and then start it the brake pedal goes down so brake assist should work.
Had the callipers off and pistons were moving fine.
Also replaced the brake assist and master cilinder.
who's got any ideas what could be the problem.
setup is 2wd 283 mm 4 pots @ the front and 253 mm disks with sierra calipers @ rear and wilwood bias.
Thanks
Old Jul 2, 2009 | 07:12 PM
Antti O's Avatar
Antti O
I have exact same problem, i will next replace brake booster (servo)
Brakes properly bleeded and all brakes rebuilded.
(2wd cosw discs front with std rst calibers and rear drums
Old Jul 2, 2009 | 08:42 PM
PaulT's Avatar
PaulT
Is there not an adjustment bar if you remove the master cylinder to apply more effort to the servo?
Cheers PaulT
Old Jul 3, 2009 | 04:09 PM
Gregor's Avatar
Gregor
Cheers PaulT
I'll have a look but now it's like it's not doing anything
yatta
May 21, 2016 10:31 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
