Diff pinion nut?
Old Jul 1, 2009 | 08:08 AM
martysport's Avatar
martysport
Default Diff pinion nut?
Does anyone know the size of the rear diffs pinion nut? It's a 12 sided nut but I'm unsure of its size.
Old Jul 1, 2009 | 10:51 AM
Mike1's Avatar
Mike1
Do you mean the one that holds the pinion flange on? It's a self locker if it's the one I'm talking about and you can only use it a couple of times before replacing.
Are you replacing the pinion seal?
Old Jul 1, 2009 | 10:59 AM
martysport's Avatar
martysport
Nope M8, the 12 sided nut the holds the pinion in the diff itself.
Looks like its might be either 36mm or 38mm but I can't get it off untill I make a tool to suit but I need a 12 sided socket 1st to fabricate a tool.
The 'other' nut you are on about is just a 24mm locknut that holds the driveflange on, that ain't a problem
Old Jul 1, 2009 | 11:20 AM
Mike1's Avatar
Mike1
Ah right, the one you need to take the circlip off for. You can get a special wrench to take off the star type nut
Old Jul 1, 2009 | 11:42 AM
martysport's Avatar
martysport
No circlip there (nor should there be ) I think you are getting mixed up with the crownwheel
Old Jul 1, 2009 | 12:14 PM
2ndGear's Avatar
2ndGear
and i think its left hand thread!
Old Jul 1, 2009 | 01:26 PM
Mike1's Avatar
Mike1
No idea really chap - I only got as far as replacing the pinion oil seal so didn't get down that far. I'm just going from what the Ford manual and diagrams say as I got them out to do the oil seal. It shows a special star wrench to remove that nut and putting a chisel in the circlip groove
Old Jul 1, 2009 | 03:18 PM
martysport's Avatar
martysport
Yes it is
I have a 'mangled' nut looks like it 'might' be 38mm but I've been told that the 'might' be 36mm but not sure.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
