2wd cosworth engine/ turbo/injectors/anitlag
i have my 2wd engine for sale. alloy pulley crank pulley, new belts, new cam gasket, high pressure oil pump, good engine no smoke or rattles. £1200.
group A t34 turbo with restrictor ( turbo technics S122 £1280 + vat)
almost new £600
grey injectors reconed £100
antilag throttle body and iscv £150
dome motorsport wrc spec p8 ecu wired for antilag and water injection £450
will consider offers cheers
almost new £600
its a .63 housing and its quick release, inconel shaft 7 degrees and 360 degress thrust bearing ,ALS, if you want to look it up on the turbo technics catalogue you can ,cheers
nah no way im just gona sell the engine, ecu ,suspension and brakes .keep the rest till i get back and finish it!!! i also heard on the grapevine from Ireland that Colin Mcrae maybe had it for a while if thats the case im definitely keeping it !!!
well if you need the money...........have you sent off a v888 form to dvla they will tell you all previous owners you never know,going to do mine when i get round to it,started collecting bits and i have started rubbing it down for paint........did you buy your solid beam mounts new?
if so where did you get them from?
cheers mate
cheers mate
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
