SEC's coolant alarm
Old Jun 27, 2009 | 06:46 PM
boost mad's Avatar
boost mad
Default SEC's coolant alarm
Secs monitor reading -40c why ?
cheers
Old Jun 27, 2009 | 09:10 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
strange? Have you check the wiring for the temp wire. Some people say take the wiring plug out the back of the monitor for a few mins for it to sort reset. Check the connection at the ecu end of the wiring
Old Jun 28, 2009 | 01:43 AM
boost mad's Avatar
boost mad
IT hasnt been check i dont think, will see if it can be looked at tomorrow
cheers
Old Jun 28, 2009 | 07:24 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Blue coolant temp sensor fucked
Old Jun 28, 2009 | 08:08 AM
Neil S's Avatar
Neil S
You've got an open circuit on the connections from the monitor to the ECT sensor. Either the sensor is poked, or the wiring somewhere - how did you make the connections onto the ECU plug?
Old Jun 28, 2009 | 10:54 AM
boost mad's Avatar
boost mad
The SECs was fitted when the car was bought.
Im pretty sure the ECT sensor would be fine, as it runs fine, doesnt over fuel etc
I will see if we can check the wiring today
cheers for the help
Old Jun 28, 2009 | 04:48 PM
ybturbo's Avatar
ybturbo
Maybe the wires from monitor to the ecu are a bit loose so it is reading a very high resistance? (more resistance = lower temp)
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
Nov 1, 2015 06:53 PM
Botts
Sep 22, 2015 02:04 PM
pabloXR
Sep 21, 2015 12:42 PM
Iain Mac
Sep 13, 2015 09:16 PM
