Escort Rs
Old Jun 27, 2009 | 04:30 PM
dan-dan's Avatar
dan-dan
Default Escort Rs
Hi people, after a little advice to do with ignition timing. I have put another engine in my rs it a standard engine, if I come off the throttle now its poping and banging through the exhaust at medium to high revs. the engine has got all the original sensor on it the TPS is set correctly aswell, only reason i ask about ignition timing is i have had to change the distributor last week, i set the timing back roughly where is was.
does the timing alter to do with mods at all?
it is a standard engine with standard cam, its got a stage 1 t3 and a big intercooler, runing a bar of boost. Thanks in advance
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
