3door fuel guage
Old Dec 12, 2004 | 08:02 PM
G500COS's Avatar
G500COS
Default 3door fuel guage
For some reason the fuel guage on my cossie doesnt work, no matter how much fuel you put in it wont go up and I have to rely on the petrol light to come on and tell me when to refill. How can I fix this and is it a easy job to do????
Old Dec 12, 2004 | 09:05 PM
Hectori's Avatar
Hectori
if your petrol light works, i think fuelgauge itself is broken. you need a multimeter (volt-ampere-ohmmeter) to check if it works. it`s easy job, if you know a bit about electricity.
but i think you first should check that fuel sensor works. you test whit your multimeter how many ohms the sensor shows when its Empty and how many ohms when full. then slowly move sensor from empty to full, and watch that ohms rise and lowers smoothly, as you move fuelsensor. then if it works, you put sensor in one position, and look how many ohms there is. then you check if there is same amount of ohms, in your fuelgauge. if there is same amount of ohms, you have broken fuelgauge. buy a new one.
note, you have to turn cars power on, when checkin fuelgauge.
Old Dec 13, 2004 | 04:52 PM
B11GNS's Avatar
B11GNS
G500COS, if you need another gauge send me a PM, as i have a spare. I bought a set of clocks a while ago as i needed the rev counter out of it.
Old Dec 13, 2004 | 10:20 PM
G500COS's Avatar
G500COS
B11GNS cheers m8 il be in touch if I need one, nice on hectori for the tip.
The guage moves up slightly, but il have a good check on the weekend and post back the result
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
