4x4 front hub drive flanges
Old Jun 26, 2009 | 11:21 AM
col93saphcos's Avatar
col93saphcos
Question 4x4 front hub drive flanges
hi,are the drive flanges that go through the hub the same on all 4x4 models?like would xr4x4 flanges be ok in a cossie hub?
thanks
Old Aug 24, 2010 | 07:26 AM
RS500/364's Avatar
RS500/364
no one then !
Old Aug 24, 2010 | 04:33 PM
Best way to be 100% sure is check part numbers, I can't see why they would be any different, the 2wd cossie hub flange is no thicker than a std 2wd one I do know, as I've measured them but never 4wd.
Old Aug 24, 2010 | 07:44 PM
PAUL S's Avatar
PAUL S
Yes they are the same, the only difference is the actual driveshaft is longer on the normal non cos 4x4 ones but these can be swapped over or kept as they help if the car has been lowered.
Old May 27, 2017 | 04:01 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
There are probably no other Ford hub flanges that are same as 4x4 Cosworth's? As for example mk1/mk2 Mondeo front hub flanges look very much the same, but surely they must have slightly different dimensions?
Old May 27, 2017 | 05:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
From memory they are different as I needed a set for my Xr hubs and was asked which version I wanted
Although saying that I know the Granada 4wd hub flanges are a direct swap as I've done it
Old May 27, 2017 | 05:31 PM
Caddyshack's Avatar
Caddyshack
You boys are answering a thread from 2010
Old Jun 4, 2017 | 04:48 PM
col93saphcos
Lol,that was a while ago,
as said they were the same,
they do seem to wear where inner bearing race sits,think I've replaced them a couple of times over the last 15 year,
Colin
Anutternutter
Aug 21, 2015 06:07 PM
C2 MAK
Aug 20, 2015 09:46 PM
IAN RS2k
Aug 18, 2015 07:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
