The actual number printed on the end of the can bit ends with -31, hence it's nickname.
Usually rubs off ever so easy so you can't read it though!!
Yep, thats the case... the only thing i have is the front part number which is Y5 9.165 43009967 (the 67 could be G7 as it is not so clear)...
