FAO Polished Bliss
totally loving all your threads on here and DW, what do you make of the HD wax from Autoglym? also the best product to get a deep shine for a grey Nissan GTR and a new blue Focus RS?
The GTR has very healthy paint readings all over and the Focus well its OK under the sun gun both cars have little, nearly no marks on them the Focus has light swirl and scratches.
also bird shit!!!!! gloss it aggresive clay could not even shift the residue(sp) from what was left on the car (BMW), it was like someone had pulled a sticker off and all that was left was a shiney none sticky film
Andy
Andy
Andy
Andy
For polishing the cars mentioned above, please note that they will have very different paint types - the GTR will be soft, while the RS will be hard. Thus, a different appraoch will be needed on each. See here...
GTR - By Hand: http://www.polishedbliss.co.uk/acata...e-faq.html#3.5
GTR - By DA machine: http://www.polishedbliss.co.uk/acata...e-faq.html#3.8
RS - By hand: http://www.polishedbliss.co.uk/acata...e-faq.html#3.7
RS - By DA machine: http://www.polishedbliss.co.uk/acata...-faq.html#3.10
Also, the bird crap mark you describe sounds like sub-surface etching, caused by the uric acid in the crap eating into the surface of the paint (this would explain why the clay didn't touch it - clay removes bonded dirt and grime, but does not address sub-surface defects etched into the paint). The above polishing methods should help to correct the mark, but note that sometimes etching can be so deep that no amount of polishing can safely remove it.
When it comes to protecting both cars, I would suggest carefully reviewing these links...
GTR - http://www.polishedbliss.co.uk/acata...e-faq.html#4.2
RS - http://www.polishedbliss.co.uk/acata...e-faq.html#4.4
If you want to save some cash, then the Werkstat Acrylic system would look ace on both; see some example images on a grey GTR here...
http://www.polishedbliss.co.uk/acatalog/may.html
I hope that helps!
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
Indyrs
20
Sep 1, 2015 09:04 AM
