rs turbo cam kits
Old Dec 11, 2004 | 04:48 PM
swerv's Avatar
swerv
Default rs turbo cam kits
right people in the know i need to replace the cam in the missus car and i want a better one thats already in there , it has a piper T2 at the minute and its a truley horrible cam!!
she needs the cam to be lively down the bottom rather than a cam that produces the power at the top of the rev range!
what options are there , apart from the usual kent/piper?
its a fairly standard spec btw , standard comp and head but with stage 3 turbo and cooler.
any help appreciated
Old Dec 11, 2004 | 06:35 PM
sf's Avatar
sf
Default Re: rs turbo cam kits
newman cam
Old Dec 11, 2004 | 07:15 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Standard wld be ideal for what she wants atleast. . .
Old Dec 11, 2004 | 07:18 PM
swerv's Avatar
swerv
anymore info on the newman cams???
yeh i thinking standard but not sure if an uprated one would be better with the bigger turbo and it would be using a vernier as well
thanks for the replys
Old Dec 11, 2004 | 10:51 PM
mitchrs's Avatar
mitchrs
few people have told me to go for a newman cam, apparently the absolute bollox!!!
phone AVA on 01418485257.
Old Dec 12, 2004 | 12:07 AM
GrimmeRS2K's Avatar
GrimmeRS2K
kent cvh 34 in mine, pulls all the way through!
Old Dec 12, 2004 | 05:50 AM
james_birch's Avatar
james_birch
dont go newman if you want it low down!
only afetr market cam that goes from low down is kent cvh34 1.5k to 7k and piper 285t 1.5k to 6.5k tho u might wanna check pipers web site!
But if you want low down go standerd!
Bur i garenty she will miss the power of the T2 ment to be like +26bhp!
tell her to adjust her driving style!
dont let the revs drop!
HTH
Old Dec 12, 2004 | 10:56 AM
sf's Avatar
sf
as mitch says phone ava they will sort u out wi one, best wi solid taps too,
might as well put on a stage 3 turbo aswell u will only want to go faster and faster
Old Dec 12, 2004 | 11:10 AM
swerv's Avatar
swerv
Old Dec 12, 2004 | 12:02 PM
sf's Avatar
sf
oops, well skim 1mm off the tops of pistons then
Old Dec 12, 2004 | 12:29 PM
swerv's Avatar
swerv
there is no chance the engine is coming apart , so i will have to work round what is a standard engine.
Old Dec 12, 2004 | 02:11 PM
220TC's Avatar
220TC
a standard cam should be used with a stage 3 turbo !
Old Dec 12, 2004 | 02:41 PM
C2RST's Avatar
C2RST
i would say standard or cvh 34 because that stage 3 turbo will have increased lag and the only way to counteract this is to go for a standard or standardish cam
Old Dec 12, 2004 | 09:50 PM
swerv's Avatar
swerv
yeh , im gonna look into the standard cam, is the rs turbo cam the same as other CVH's i.e xr3i???
Old Dec 13, 2004 | 07:01 AM
JesseT's Avatar
JesseT
All 1.6 cvh cams are the same for except the efi cam.
Old Dec 21, 2004 | 02:10 PM
turbo stealth's Avatar
turbo stealth
if you speak to any DECENT tuner they will tell you that the standard cam is quite sufficient for over 200 bhp
Old Dec 21, 2004 | 04:29 PM
vroooom ptssssh
It Wasnt Me!
yup std cam as i first said
robnock
21
May 13, 2019 05:29 PM
Danielbetty
Oct 3, 2015 06:01 PM
Matt Baxter
Sep 16, 2015 08:30 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
robnock
Aug 22, 2015 10:51 AM
