oil flush
Old Jun 17, 2009 | 09:31 PM
costina's Avatar
costina
Live long and prosper!!
Default oil flush
Can anyone recomend one?
Paul
Old Jun 17, 2009 | 09:33 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Nooooo. Just do a couple of short oil changes. You can do more harm than good.
Old Jun 17, 2009 | 09:49 PM
burnzy's Avatar
burnzy
burnzy
just out of curiosity how come mal cos your running the engine on contaminated oil and it can damage journals, or eat seals cos of the chemicals, i always liked to flush my engines to get the crap out of oil-ways and so forth admitted i'll usually get the sump off and rocker cover and do that lot by hand it's so depressing giving your car an oil change to find 50 miles down the road your oil looks dirty again
Old Jun 17, 2009 | 09:58 PM
Dangerous Malcolm..
If you remove and clean your rocker cover and sump then fair enough. But sometimes the flush can dislodge otherwise harmless lumps of shite. As a case in point my uncle ran a flush through his rover diesel and within a few miles suffered camshaft failure due to oil starvation. On stripping down a lump of what can only be described as varnished oil residue had blocked the oil way. I've also read on t'internet pretty much the same.
Old Jun 17, 2009 | 10:15 PM
burnzy's Avatar
burnzy
burnzy
ok sounds a very valid point , to be honest i'm sure iv heard that about but never bothered me because of the fact i'll usually clean valve-train and rocker cover and sump and pickup and wherever else i can get my grubby fingers into () at the same time i do a proper service on my cars
Old Jun 18, 2009 | 09:10 AM
If your uncles car had been properly maintained using decent oil in the first place this would never have happened.
You cannot keep the oil clean FACT, you burn fuel which is fossil fuel you produce carbon, simple as that, some gets past piston rings and turns the oil black, higher compression on diesels means more blow by rings more carbon more black even quicker.
You can slow down the process by ridding the internals of all the varnish etc from the oil that has accumulated but never 100%.
I use WYNNS, it is very soft and leave it in for 200 miles before oil change, never a probe in 20+ years.
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
