Rear Diff Pinion Oil seal
Old Jun 16, 2009 | 07:51 AM
Mike1's Avatar
Mike1
Default Rear Diff Pinion Oil seal
Anyone replaced theirs? Got a small leak from mine - had a look in the manual about it and it mentions a special tool to lock the pinion flange so you can remove the retaining nut?
Anyone know how hard a job it is without that?
Also what oil have you topped up with - says Hypoid Oil SAE90 ( Ford Spec SQM2C-9002-AA ) - is that only from Ford dealer or do Halfords do something.
I presume the seal is still available? Anyone done theirs recently and got a finis code?
Any other parts I might need from experience?
Old Jun 16, 2009 | 05:33 PM
Mike1's Avatar
Mike1
For info - it's on backorder - finis code 6099522.
I shall try and source one elsewhere
Old Jun 18, 2009 | 07:40 AM
Mike1's Avatar
Mike1
In case anyone else is ever after one, I found them on Ebay ....
here -> http://cgi.ebay.co.uk/FORD-SIERRA-in...3A1%7C294%3A50
The correct size is 40/75/12 for the pinion, many bearing places keep 40/75/10 in stock but not the extra 2mm deep ones.
I'm hoping it isn't the washer missing off the pinion flange ( the bit you have to pull off to get at the seal ). Anyone got a pic of the flange with the retaining nut removed?
Danielbetty
Aug 28, 2015 08:01 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
st220kyle
16
Aug 14, 2015 06:13 AM
Gadget
Aug 13, 2015 08:19 PM
xr4x4rs
Aug 6, 2015 09:03 PM
