standard or low compression for 400 bhp
as above i have bought blacks and got t34 63 going to get bd14 but just had valve cut outs put in standard comp pistons but now starting to worry about reliability
should i just go greens and 350 bhp
most standard cossies have had piston to valve contact, so valve cuts out are a good idea
t34.63 with blacks and other supporting mods should see a very strong 380hp.
just make sure all the basic things are done right, eg. rewired fuel pump for a direct feed from battery, 30 min job, cheap and essential!
stick with standard cams and standard compression, but valve cut outs are always a good idea even on standard cams & compresions.
Mines std compand and the last time it wa on the dyno it made 397.8bhp and 400lbft of torque with std cams, 4x4 inlet 55lbs siemens, Tb34.63 +all the std bits ie 3 bar, 044 fuel pump, 500 style cooler etc etc
What would be the advantage of standard cams?
I have spoke to will at msd and he said to use this spec.
Its going in a rwd escos so should go ok
bd14 inlet, std ex, is a nice combo, and does work quite well on the t34.63 with the correct software.
it will make more power than with the std cam, but you will lose a bit of torque on the way there, so it all comes down to what you want to do with it tbh, if its a track car then drivability isnt so much of an issue, and i would opt for the power in that instance
if running a bd14, it may be worth thinking about double springs for added safety,
and it also depends what software and map you intend to run, ie closed loop off the shelf can be more tricky to get right with a funky cam, although imo the exhaust cam would be more critical here
the mind boggles than people can advise on whats best for you, and yet nobody has asked what you actually want from the car or what you intend to do with it
Folks,
Slighlty off topic..
How much does a PROPER Stage 3 set-up cost these days??
I.E 500 Cooler/ T.34/ Live Map/ -3/ 3bar/ Seimens..etc etc.
Already have Pump and new AP clutch...
Would you need 3kish to do it???
I know i should know, but it,s been a while since i,ve spent on a cossie..
Folks,
saff is working!!!...atm
rough......cooler £350-400....-31/-34 £70.......3bar £60.....seimens under £200 (easy) but plenty peole will rob u.......live map...£500ish........new turbo...???
as a guide, most of mine was 2nd hand
pace 500 cooler £150
t34.55 £375
siemens £150 (brand new, imported from the US, cheaper
3 map bar £35
MSD chip (not live map) £300 ish
-31 actuator £30
set it up myself, 2 bar of boost, estimate 360-370hp
will be alot more expense to have a live map & new turbo, that's would be best part of £1300 alone
stage 3 doesnt necessary need a live map; but as ever its the best option.
t34.55 £375
3 map bar £35
-31 actuator £30
Cheers fellas, appreciate that...
It,d be new parts tbh i think, i,m a fussy twat like that..
So a 3k budget should surfice then??
My other option which i,m looking into is the NMS Gunship which i,ve heard is a cracking upgrade AND would cost alot less too..
Why do you guys still run low compression........ does it cause you that much of an issue with power limitations vs going high compression?
I see that a number of Scoob and EVO tuners are now switching to high compression.
I have just changed (Scoob) to high compression and the engine is awesome.... still managing 2bar boost on a straight VPower, but have much better response and more power at less boost and ignition.
Using a GT30 core we managed 485bhp at the fly on low boost of 1.45bar
and
486bhp at the HUBS on high boost of 1.8bar.
High compression is good.
and
and
and
do you find it makes them poor on fuel economy? or not much different?
just thinking of road car use really
There can be caveats on block integrity, as regards to how much you can push them..... but you run a cast iron Cossie block, so I can't see you having problems with your liners bursting, unlike us Subaru owners!
155lee
Aug 14, 2015 11:21 AM
