any vag techs on?
Old Jun 15, 2009 | 08:38 PM
fordsportjay's Avatar
fordsportjay
Default any vag techs on?
got a v5 passat syncro in which has just decided to overheat on us-looks like its pressurised the system and then spat its water past the pressure cap.
is there any common probs with them-water pumps,thermostats,head gaskets etc?
thanks in advance
Old Jun 15, 2009 | 08:41 PM
Oranoco's Avatar
Oranoco
The water pumps are prone for cracking so the spindle of the pump spins but the impeller doesn't causing the overheating you describe.
Old Jun 15, 2009 | 08:45 PM
fordsportjay
interesting..... are they timing belt driven?
Old Jun 15, 2009 | 09:10 PM
markk's Avatar
markk
impellor wil have fallen off, driven by the cambelt.
Old Jun 15, 2009 | 09:24 PM
fordsportjay
looks like ill be busy tomorrow then........
is it a full front panel off for this?
Old Jun 15, 2009 | 09:39 PM
markk's Avatar
markk
you can do them insitu, but for how long it takes to get the bumper off its not worth it, just check that the passat doesnt use an auxillery pump to the n/s of the engine bay for the water pump, some did.
Old Jun 15, 2009 | 09:45 PM
fordsportjay
ok cheers,ill have a look
Old Jun 15, 2009 | 09:47 PM
paul16v's Avatar
paul16v
Monte 087
Check the rubber O ring on the header tank cap hasnt flipped over.
Old Jun 15, 2009 | 10:31 PM
rs-tuner's Avatar
rs-tuner
not full front just undo the bumper and top bolts the front panel will lean forward on the front engine mount and give you enough room
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
bassboy
Sep 10, 2015 08:54 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
