Hose gone again...
Jun 15, 2009 | 04:45 PM
Hose gone again...
The hose from my breather pot to the return on the turbo side of the block has burst/melted again as it must still be to close to both manifold and downpipe - it gets hotter than i originally thought so braided will have to be fitted.
What make have others used??? and wheres the cheapest place to get it?
Jun 15, 2009 | 04:49 PM
Jun 15, 2009 | 04:59 PM
what size you using mate have a length in the garage if you want it, its got the 45 fitting on the end aswell
Jun 15, 2009 | 05:35 PM
Jun 15, 2009 | 06:32 PM
I used braided on mine with some heat sleeve over it.
Steve
Jun 15, 2009 | 07:04 PM
Quote:
Originally Posted by
Moonstone Steve
Steve
That's what i'll have to do as theirs some heat under there
Jun 15, 2009 | 07:35 PM
I use a samco silicon hose, still works!
Jun 15, 2009 | 07:37 PM
MannheimAlex
Your not driving hard enough m8
Steve
Jun 15, 2009 | 07:38 PM
BRAMMER
I have also heat wrapped the downpipe to
Steve
Jun 15, 2009 | 07:46 PM
Wanted to but kept hearing the downpipe may crack so never bothered as this is running very very hot under there
Jun 15, 2009 | 07:51 PM
I must admit when its cooling down it does make some strange noises
Steve
Jun 15, 2009 | 08:39 PM
BRAMMER
13mm mate
think mines -16 your welcome to it if you want it its sitting on the floor gathering dust
Jun 15, 2009 | 09:48 PM
I was worried about this and covered mine with with some shiny corregated aluminium stuff that you can buy cheaply for air intake pipe - works a treat
Jun 16, 2009 | 05:27 AM
bad boy rs
I take it as the -16 refers to 16mm?? if so it's too big mate but many thanks for the kind offer
AndyPen
Any you just reminded me, i have some nimbus shielding that my heatsheild is made from i'll cover it in that.
Fudgey
21
Sep 30, 2015 06:19 PM
Russ Payne
Sep 25, 2015 08:29 PM
