Dishwasher Engineer
Old Jun 15, 2009 | 09:27 AM
Brian's Avatar
Brian
Default Dishwasher Engineer
Is there any dishwasher engineers on here?
As i am having a bit of trouble with ours, It will run through a programme but before after it had dryed the stuff it would bleep to say its finished but yesturday it never so i openned the door and the bottom of the dishwasher was still filled with water so i drianed it all out and check the waste pipe for any blocks but nothing I then run it through a quick rinse wash and it was fine so i put all the mugs and dishes in there run a full programme and it done the same when i openned it up it was filled with water
Anyone got any idea's??
Brian
Old Jun 15, 2009 | 09:39 AM
rs-tuner's Avatar
rs-tuner
poss the drain pump when it does a new programme it should empty the old water see if it does that
if it does poss the wash pump is fucked
Old Jun 15, 2009 | 09:43 AM
carlfiesta999's Avatar
carlfiesta999
Programmer/control panel/circuit board thing is fucked on it.
Washing machine used to do it till change the control panel on it, works fine now.
Old Jun 15, 2009 | 10:22 AM
Brian's Avatar
Brian
Have just run it on a full programme with nothing in it and its worked fine
Going to load it up and try again
Brian
Old Jun 15, 2009 | 12:10 PM
rs-tuner's Avatar
rs-tuner
Brian
ither the pump is sticking or as said the programme board is dodgy
Old Jun 15, 2009 | 12:41 PM
Brian's Avatar
Brian
So i need a new drian pump? where will i beable to buy one of these from? are they hard to change?
Brian
Old Jun 15, 2009 | 05:18 PM
Brian's Avatar
Brian
Still wont work
Anyone know where i can buy a Drian pump for a NEFF S5444X1GB?
Brian
Old Jun 22, 2009 | 11:31 AM
Brian's Avatar
Brian
All sorted it was the drian pump, bought a new one and just fitted and now its fine
Brian
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
