L6 ecu, 2wd loom, ignition amp on bling back plate + standard pistons
2wd loom in perfect working order only removed due to going omex management, not chopped up at all, only plugs cut off are for the coil from when i had my group A fitted, every plug is labeled as i intended to reuse it but it's not going to happen. £60
L6 ecu - mapped for T35, stage 3 basically, was running 327bhp on mine. perfect working order. £100
weber mirelli ignition amplifier on a bling back plate. £20
also got a set of standard pistons from my engine, no det marks on them or anything. £ offers as i don't know what they are worth.
big_Rad
Sep 15, 2017 09:36 AM
ekjim
Aug 17, 2015 08:57 PM
muz
Aug 16, 2015 12:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
