big end movement
Old Feb 28, 2004 | 08:49 AM
rossatom2's Avatar
rossatom2
Default big end movement
hi, ust built my new bottom end of my sapp coss and i've noticed a slight move ment of the big end not only side to side but a tiny bit up and down is this normal?? cheers fo any elp
Old Feb 28, 2004 | 11:01 AM
Guinnless's Avatar
Guinnless
Errr no
Old Feb 28, 2004 | 11:05 AM
PJay's Avatar
PJay
In a word NO, what is the clearance?
Old Feb 29, 2004 | 06:08 PM
rossatom2's Avatar
rossatom2
after a closer inspection it is really just 2 of them with alot of movement i have just fitted it with standard bearings the crankshaft is mint. could the problem lie with the conrods or the bolts even though the bolts are new??
Old Feb 29, 2004 | 06:38 PM
Toe Knee's Avatar
Toe Knee
has the crank been polished/ground at all? bolts wouldnt make a difference mate if u have torqued em up properly
Old Feb 29, 2004 | 07:05 PM
rossatom2's Avatar
rossatom2
nope the crank is standard
Old Feb 29, 2004 | 11:05 PM
PJay's Avatar
PJay
Is it worn?
Old Mar 1, 2004 | 06:30 AM
alan rainbow's Avatar
alan rainbow
did standard bearings come out ?
Old Mar 1, 2004 | 10:44 AM
rossatom2's Avatar
rossatom2
the crank is not worn at all it is in mint con out of a low mileage car, but the engine that the conrods came out of was worn and the crank was knackerd.
i have had the crank checked by the local engineering firm and the said it is perfect and in standard form, cheers
Old Mar 1, 2004 | 07:53 PM
PJay's Avatar
PJay
did you use the rod caps and main caps that match the correct rod's or block if you have mixed them then you've just found your problem
Old Mar 1, 2004 | 08:08 PM
rossatom2's Avatar
rossatom2
yes the conrods caps and main caps are from the same block, the only new part is the crank.
i'm going to styrip it all down again and see what i can find, cheers
Old Mar 2, 2004 | 10:22 AM
rossatom2's Avatar
rossatom2
problem solved thank god, took it all to bits ,buuilt it back up over night and now it's sweet maybe there was some crap inbetween the rods and the caps who knows, cheers
Old Mar 2, 2004 | 10:39 AM
PJay's Avatar
PJay
If you had torqued the rod bolts i'm sure you are aware you needed to use new ones
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
rsstav
Sep 7, 2015 04:43 AM
rsturbo27
Sep 5, 2015 05:08 PM
