Flat again...........GRRRRRRRRRRRRRRRR!!
Old Jun 13, 2009 | 08:46 PM
Harris.'s Avatar
Harris.
Default Flat again...........GRRRRRRRRRRRRRRRR!!
So tonight i go out to the garage to get the 3 door out and the car starts fine, i get half way down my drive and i forgot my wallet,so i turn the car off run inside ......
Come back out to the car,go to start it and NOTHING !!!! 2 month old battery too! I dont use the car a great deal ,maybe a few times a month so what does eveyone do who dont use there car much to stop this ???
Ive heard of trickle chargers (sp) how much are they and whats the best one to get
Old Jun 13, 2009 | 08:50 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
my escort van often sits for 4 or 5 months at a time and always starts first turn of the key. i dont have it alarmed to run it down though. perhaps starting it on a weekly basis just to give it a tick over would help? i would have thought a 2 month old battery would last though?
Old Jun 13, 2009 | 09:44 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Do you disconnect the battery when it's stood?
Old Jun 13, 2009 | 10:59 PM
Harris.'s Avatar
Harris.
No as it has an alarm etc on it
Old Jun 13, 2009 | 11:51 PM
kosman's Avatar
kosman
sideways all the way!
my cossy comes out once a month normally,it stands in the garage all the alarm and immobiliser going all the time,never runs the battery down,i start it once every 2weeks,it stood for 6weeks through winter and still started so you could have a little drain somewhere,loose battery lead etc? if it started and then wouldnt start again could it be a turbo cooking your starter cos the heat sheild is nakered?
orionmojo's Avatar
orionmojo
i had that for a while with my orion turbo.
it was the little bluie wire off the alternator had degraded and was intermittent. if i swithched it on and off within about 5 mins the battery hadn't recovered enough and it wouldn't be able to start the car. i would turn over the engine half a turn, then die.
Old Jun 13, 2009 | 11:57 PM
Paulo P's Avatar
Paulo P
Must be a drain on the battery somewhere. Mine doesn't move month to month sometimes but it always fires up on the button It's been at my mates house nearly a month now and he didn't have any issues starting it to drive it to the station the other day.
Old Jun 14, 2009 | 12:15 AM
jammy86's Avatar
jammy86
Get an ammeter on it and check the parasitic load before doing anything else. (charge the battery fully first)
JAmes.
Old Jun 14, 2009 | 05:59 AM
Harris.'s Avatar
Harris.
Well ive just gone out to the car and it started ,so in a sec im going to fill it up and take it round the lanes for a few hours
Old Jun 14, 2009 | 07:56 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
Sounds like it may have a loose connection somewhere.
Steve
Old Jun 14, 2009 | 08:19 AM
LHD220Turbo's Avatar
LHD220Turbo
it'll have a battery drain on it somewhere
Old Jun 14, 2009 | 09:20 AM
May just need using, all this starting every week and that for 10 min utes does not put the same charge back in as you take out, so it becomes even more drained.
There's a old biddy round here I fitted a C tek to her car as she uses 3 times a week for a 2 mile journey(mile easch way), battery was becoming flat all the time as alarmed etc.
A better battery type to suit would pay dividends, ie a AGM, would be vastly more suited to this kind of work, and would not suffer damage everytime it gets a bit flat.
Old Jun 14, 2009 | 09:25 AM
Harris.'s Avatar
Harris.
The one on the car is a heavy duty vita , it is because when i use the car i do around 3 miles ive taken it out today and just put 60 miles on the clock with now stereo on etc .
jessie_rs
62
Aug 6, 2019 09:27 PM
stevecfrst1
Sep 30, 2015 05:18 AM
bigdel
Sep 22, 2015 05:50 PM
jay030787
Sep 18, 2015 04:38 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
