Any tv ariel/sky specialists/installers on here?
I have an outlet plate I want to put on my wall and I cant figure out how the hell to wire it up
I have 5 cables coming to the box. Two Co-ax ( one carrying signal from amp in loft and one returning it ), phone cable, and my two sky plus cables.
However on the back of the socket there are only places for 4 cables
Phone, co-ax ariel return, co-ax fm ariel ( unused ) and another co-ax ( presumably to take cable carrying signal from the amp )
however there's nowhere to put the two sky cables in, but there are two f=type outlets on the front?
It seems to me that I am needing something to combine the sky+ cables and my co-ax into one co-ax before it goes to the back of this outlet plate....is this possible?
Fucking confused!
Fucking confused!
to use that plate you would have to combine one of your sat feeds and your tv aerial together , before the socket probably best in the loft if the cables run that way , then you would have input 1 tv/sat input 2 sat , then return , then bt , if you cant do that you could look for a modular plate where you can fit single modules for each cable you have
http://cgi.ebay.co.uk/New-Satellite-...3%3A1|294%3A50
http://cgi.ebay.co.uk/TRIPLEXED-OUTL...3%3A1|294%3A50
if so it s no good to you , you need a quad version like this
http://cgi.ebay.co.uk/QUADRAPLEXED-O...3%3A1|294%3A30
this one will have 2 inputs on the rear of the quad plate(tv/fm/dab /sat1/sat2) and 1 separate one for the return and 1 for the bt , the 2 input s on the rear of the quad plate it just has one outer braid clamp for both inputs you slacken this off and the center core of each cable just pushes inside and the braid clamp tightens onto both the cables in one go , it might look like only one connection but there is deffo 2 there , make any sense ? should look something like this one
http://www.satcure.com/tech/triax_304114.htm
or something simpler ?
http://www.satcure.com/accs/images2/plate5f_0824.jpg
I got it now....use one input for tv ariel and one for the two sky cables joined together using this http://www.maplin.co.uk/Module.aspx?...C=SO&U=strat15
Agreed?
Agreed?
still not quite , one of your sat feeds will go into the sat side of this combiner http://cgi.ebay.co.uk/New-Satellite-...294:50&afsrc=1 your tv aerial will go into the other side and the common out put will go into input 1 of the quad socket , then 2nd sat feed straight into input 2 of quad plate
got it....wohooooooo http://cgi.ebay.co.uk/ws/eBayISAPI.d...fvi%3D1&_rdc=1
Fuck me it's a mission to understand
thanks for all help
thanks for all help
