L8 MSD Launch control
Old Jun 13, 2009 | 10:29 AM
Paul_RS's Avatar
Paul_RS
Default L8 MSD Launch control
Does anyone know what pin you have to earth to activate this?
Old Jun 13, 2009 | 10:30 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
13 iirc
Old Jun 13, 2009 | 10:32 AM
Paul_RS's Avatar
Paul_RS
Cheers lad
Want to come over here and fix my car?
Old Jun 13, 2009 | 10:33 AM
JTECH James
Passion for Fords!
lttle bit far, i could meet you half way? lol
Old Jun 13, 2009 | 10:35 AM
Paul_RS's Avatar
Paul_RS
I'll buy you a guiness and a sausage supper if you come? :P
Old Jun 13, 2009 | 10:36 AM
JTECH James
Passion for Fords!
mm, tempting
as long as its not your sausage
Old Jun 13, 2009 | 10:37 AM
Paul_RS's Avatar
Paul_RS
I thought we had something special going as well
Old Jun 13, 2009 | 10:47 AM
DAN400's Avatar
DAN400
paul were you at the show last week, it was after 3 before i got down !
Old Jun 13, 2009 | 12:47 PM
Paul_RS's Avatar
Paul_RS
I didn't take the car up, just went up with a few friends for a walk round. Seemed like a good show, but apart from the new RS there wasn't anything i hadn't seen before.
You have a good stag do?
Old Jun 13, 2009 | 02:38 PM
KSA-Cossie's Avatar
KSA-Cossie
Isn't 13 als ?
Old Jun 13, 2009 | 02:53 PM
JTECH James
Passion for Fords!
may be 14 then lol, i think u may be right actually
Old Jun 13, 2009 | 05:30 PM
Paul_RS's Avatar
Paul_RS
It is 14,
However i seem to get 30+psi at 3000rpm ish, so i won't be using that again
Thats with a standard ISCV too!!
Old Jun 15, 2009 | 04:43 PM
BillsCossie's Avatar
BillsCossie
what colours 13 and 14 its the two on the seperate plug off the ecu?
Old Jun 15, 2009 | 04:50 PM
stu21t's Avatar
stu21t
both are black.
how nuts does the car sound with it switched on lol
its even mader with als switched on to.
and ive opened up the iscv to lol.
Old Jun 15, 2009 | 05:17 PM
BillsCossie
spotted them im just waitin on gettin the chip ordered msd als and lc chip from stu should be the job!! hopefuly have it fitted this week.
Old Jun 15, 2009 | 05:21 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hi paul,
Did you not get any instructions mate?
Be aware that the ISCV port size only affects ALS because with launch control your throttle is wide open anyway.
Old Jun 15, 2009 | 06:00 PM
andy escos's Avatar
andy escos
ive got als & launch & i havent tried either yet cars been in bits since i fitted my new chip should be up & running by saturday for cornwall rsoc show ill try & wire it up by then
Old Jun 15, 2009 | 07:22 PM
stu21t's Avatar
stu21t
you wont be dissapointed.
just make sure no1 is behind you when you try it. pmsl
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
RSmark84
Sep 13, 2015 01:29 PM
