whats an acceptable ammount of knock ?
ive got a knock sensor readout on my power fc ecu and it reads up to 100 %. what is acceptable ammount of knock to see ?
PowerFC knock reading using standard Knock sensors on a Skyline should be set with a warning threshold that when hit will light the management light (depending of course on the mapper)
This limit is usually set to 40 on most cars, but I think it's 60 on Skylines. Anything up to this amount is 'OK'. Spikes beyond this amount may be acceptable too if they really are just spikes and you don't actually 'see' them occur.
you can have pressure values at what the det is at but not a percentage of a det.
apparantly it spikes 100 but doesnt hold it il check it today. thanks for the info matey.
i would spend the money rebuilding youres than buying another...
They are all low miles when they are being sold.
Speak to tweenierob im sure he will help sort it, I always used ron at RK but as rob know the car already he may be better for you.
i think il ring him monday as he knows the car. i got a friend of mine gonna have a listen tmrw. ive read they have a common fault with the oil pump on the pre 1992 rb26detts. it certainly doesnt sound or feel like a big end failure to me. im gonna go check prices on rebuild parts now
i would deffo rebuid rather than buy another....
Im sure ron quoted me a freshen up at 3k...
He also quoted rb30 700hp+ for like 20K+ lol.... Its easy to get carried away with these
well ive got a light that seems to flash on when i hear the rattle noise. just found out light is cat overheat light ?
It will put in a high peak if you crack the rev limit. That's why you need to see where in the rev-range it's doing it. If it's right at the end of the rev's, don't worry too much, if there wasn't anything too high before that.
im gonna get my mate to watch the power fc monitor while i drive it tmrw. what would the garage where you work charge for an engine freshen up mate ? shouldnt be to bad cars only done 55000 miles.
