cossie ign amp question
Old Jun 12, 2009 | 08:39 PM
stu21t's Avatar
stu21t
Default cossie ign amp question
where do these normally fit?
are they bolted to the body? so the heatshink is earthed by bolting to the chassis?
reason i ask is in the wiring diagrams it says your supposed to connect an earth lead out of the ign amp onto the heatsink then to the engine
i want to know if i can bolt the heatsink down to the chassis, earthing it or if i need to insulate it from the chassis 1st
cheers peeps.
Old Jun 12, 2009 | 08:42 PM
Alvyn's Avatar
Alvyn
just bolted to inner wing near the battery tray on my saff
Harris.'s Avatar
Harris.
There on the passenger side inner wing , screwed to a alloy plate
Old Jun 12, 2009 | 08:57 PM
stu21t's Avatar
stu21t
cool, is the alloy plate screwed to the inner wing to? or insulated from it?
Old Jun 12, 2009 | 09:39 PM
Harris.'s Avatar
Harris.
Sure its screwed mate
Old Jun 13, 2009 | 10:19 AM
Alloy plate is just screwed to the inner wing near battery, they need to have FUJIC or similar between amp and alloy plate to aid heat dissipation though.
Old Jun 13, 2009 | 11:12 AM
stu21t's Avatar
stu21t
cool
thanks
Old Jun 13, 2009 | 01:02 PM
You can buy FUJIC on www.dealextreme.com only around $2 delivered.
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
