Decent plugs for 380 bhp cossie (not denso)
Old Jun 12, 2009 | 08:15 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Decent plugs for 380 bhp cossie (not denso)
Thats the 2nd set of ik31's fucked in under a year,do i go back to 071's or any other recommendations ?
Old Jun 12, 2009 | 08:18 PM
JamesH's Avatar
JamesH
Fuck me Kev, was told they are the nuts mate... was gonna get a set... not now!!
Champion C57 or 59's do us pretty proud
JamesH's Avatar
JamesH
P.s you northern fooker
Old Jun 12, 2009 | 08:19 PM
DAN400's Avatar
DAN400
denso s in mine , never a problem, but my mates cos eats plugs all the time , why ? if i change mine , i m goin back to the motorcrafts £12 ones
Mark Shead's Avatar
Mark Shead
They are if you are sold the correct heat range.
Mark
Old Jun 12, 2009 | 08:20 PM
KSA-Cossie's Avatar
KSA-Cossie
I was told that too Have just ordered some 071's to try .
Southern poooooooooooooof
Alvyn's Avatar
Alvyn
well I know alot of people DONT like them but I run Champion c59c in mine which is just under 400 bhp with NO PROBLEMS at all and c57c in the 3dr that's over 400 again with NO PROBLEMS!
Old Jun 12, 2009 | 08:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Mark
What would you advise mark ?
Old Jun 12, 2009 | 08:23 PM
Mark Shead's Avatar
Mark Shead
IK27
Mark
Old Jun 12, 2009 | 08:24 PM
JamesH's Avatar
JamesH
Best put our flame suits on mate. I know they do have their problems, but never had a misfire due to one other than at idle
Old Jun 12, 2009 | 08:25 PM
JamesH's Avatar
JamesH
I was advised IK31 by a tuner the other week
Is there a guide with the temp ranges Mark?
Old Jun 12, 2009 | 08:28 PM
Mark Shead's Avatar
Mark Shead
Yes my giude 24 up to 360hp, 27 from 340 to 630hp. 31 550hp to 1000hp+.
Mark
Old Jun 12, 2009 | 08:29 PM
JamesH's Avatar
JamesH
Out of interest Mark, why has Kev had 2 set of 31's go if they're recommended for the higher hp engines?
Old Jun 12, 2009 | 08:35 PM
Mark Shead's Avatar
Mark Shead
When running such cold plugs you need to make sure the engine is not to rich and floods its plug,
If you keep starting the engine and not warming the plugs you will kill them, I recomend when doing this is to hold the revs to 2.5k until the engine clears itself after 30sec then they are normaly fine to starting the car,
If misfiring under boost you will need to close the gaps to the correct range for your coil system,
Running 31's as such low power is IMO not the correct way to run this plug.
Mark
Old Jun 12, 2009 | 08:37 PM
KSA-Cossie's Avatar
KSA-Cossie
IK27
Mark
Thanks m8,i've been doing a lot of short journeys lately could it be that thats done it ?
Old Jun 12, 2009 | 08:39 PM
Mark Shead's Avatar
Mark Shead
What goes wrong with them.
Mark
Old Jun 12, 2009 | 08:41 PM
KSA-Cossie's Avatar
KSA-Cossie
Weak spark a very dull orange colour spark
Old Jun 12, 2009 | 08:43 PM
Mark Shead's Avatar
Mark Shead
But what problem do you have with running.
Mark
Old Jun 12, 2009 | 08:44 PM
KSA-Cossie's Avatar
KSA-Cossie
Missfire at idle and part throttle then all the time afte a short while
Old Jun 12, 2009 | 08:46 PM
Mark Shead's Avatar
Mark Shead
To cold plugs causes this.
Mark
Old Jun 12, 2009 | 08:47 PM
JamesH's Avatar
JamesH
Sorted Kev
Old Jun 12, 2009 | 08:48 PM
KSA-Cossie's Avatar
KSA-Cossie
Gonna order a set of ik27's and try them thanks very much for your help mark.
Old Jun 12, 2009 | 08:49 PM
KSA-Cossie's Avatar
KSA-Cossie
Sorted Kev
Schwing.
Old Jun 13, 2009 | 05:55 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
i have used NGK bk9iex iridium plugs for over 3 years now (400bhp) and never missed a beat.....i'm only just on my second set as i fooked one checking the plug gap...............less than £30 delivered
Old Jun 13, 2009 | 07:12 AM
KSA-Cossie's Avatar
KSA-Cossie
Stuck a used set of 071's in this morning till my ik27's arrive and she purrs like a kitten again.
Old Jun 13, 2009 | 08:24 AM
jemis's Avatar
jemis
how much are the ik27's and where from
Old Jun 13, 2009 | 09:23 AM
silky16v's Avatar
silky16v
Get on That!
071'c never used owt else never had a problem and i always carry a spare set in the car
Old Jun 13, 2009 | 10:08 AM
I've been using IK27 for years now, never a problem, had the same with 31's fouling under constant city work, so just put in hotter running plug, the 27's, does city stuff fine now.
Old Jun 13, 2009 | 02:40 PM
KSA-Cossie's Avatar
KSA-Cossie
Opie oils delivered for £40
Old Jun 13, 2009 | 03:00 PM
col cos1's Avatar
col cos1
ngk bcr8es are spot on ive always ran them,work pefect kev and only around a £10 for 4
i had those £50 ones woodford sell and the car misfired
Old Jun 13, 2009 | 08:48 PM
Turner RS's Avatar
Turner RS
This is because they are the ONLY plug for a YB cosworth.
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
dojj
28
Sep 11, 2015 10:00 PM
28
Sep 8, 2015 07:10 PM
Thanasis
Sep 7, 2015 07:33 PM
Shows & Track Days
Sep 4, 2015 07:16 AM
