how hard to make a turbo damper?(done)
Old Jun 12, 2009 | 06:29 PM
stevenebm's Avatar
stevenebm
post whore
Default how hard to make a turbo damper?(done)
need one to support my turbo over my gearbox and looking at a bailey cosworth one it looks like two rose joints with some legs welded on.for over a £100 quid im sure i could knock one up for the price of two rose joints.is there something special about a bailey one that im missin
Old Jun 12, 2009 | 06:30 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
easy
Old Jun 12, 2009 | 06:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
very difficult. you would need to know the reasonant frequency and how to dampen it etc.
a turbo support, or hanger as they are commonly known is much easier
Old Jun 12, 2009 | 06:53 PM
stevenebm's Avatar
stevenebm
post whore
ok well hanger then
Old Jun 12, 2009 | 07:30 PM
Diy mate, easy enough.
Old Jun 12, 2009 | 07:34 PM
stevenebm's Avatar
stevenebm
post whore
just ordered my rose joints,£12 it cost me.will have rest of stainless bar etc at work.will post pics when i get it done
Old Jun 12, 2009 | 11:55 PM
Red16's Avatar
Red16
Good good... looking forward to seeing it i still have to make one for R6Franky's zetec turbo.
Old Jun 12, 2009 | 11:57 PM
Luca's Avatar
Luca
Lukesville
Hows it looking mate you made it yet
Old Jun 13, 2009 | 08:14 AM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
there you go mate 2 rod ends , stainless steel bar and hey presto! one turbo hanger , hang the rod end off the turbo bolt in the compressor housing and not of the turbo flange as the heat will knacker the rod ends in no time
Old Jun 13, 2009 | 08:50 AM
stevenebm's Avatar
stevenebm
post whore
any bigger pics paul.i ordered a new damper bracket for the turbo so will mount it there
luca will start it sunday nite when i get to work
Old Jun 13, 2009 | 10:39 AM
carlo's Avatar
carlo
Get andy to make you one mate
Old Jun 13, 2009 | 10:55 AM
stevenebm's Avatar
stevenebm
post whore
if the car was on the road mate id have been straight over for him to do it plus we arent busy at work just now so i have all night to play on the welders etc
Old Jun 16, 2009 | 01:42 PM
stevenebm's Avatar
stevenebm
post whore
quick update.got a few parts today,got a mock up of the legs also.will have to turn down the main body as its a bit thick.obvioulsy nothing is welded as im just heading out to garage to get a few sizes but should prob have it nearly completed tonight
Old Jun 16, 2009 | 03:00 PM
steviecossie's Avatar
steviecossie
so far so good mate
Old Jun 16, 2009 | 03:27 PM
Luca's Avatar
Luca
Lukesville
BLU TAK FTW!
Looking good that mate
Old Jun 16, 2009 | 03:38 PM
stevenebm's Avatar
stevenebm
post whore
blu tacwill ge more pics tommorow hopefully,might only be tac'd up as my welding is a but crap being a spark to trade and the welder at work is on the other shift so will get it left out for him but i will tac it atleast
Old Jun 16, 2009 | 04:56 PM
stevenebm's Avatar
stevenebm
post whore
never mind blu tac luke.heres some insulating tapejust to hold it to see if it looks decent.not bad i reckoneverythings a bit messy in there.needs a good clean when its done.
Old Jun 16, 2009 | 05:09 PM
Stoo's Avatar
Stoo
YOU made that? I'm almost impressed!
Old Jun 16, 2009 | 05:16 PM
stevenebm's Avatar
stevenebm
post whore
im in the process of makin it.should have most of it done tonight
Old Jun 16, 2009 | 06:38 PM
foreigneRS's Avatar
foreigneRS
Testing the future
there's next to no strength in that without making a triangle in the vertical plane
Old Jun 16, 2009 | 06:55 PM
stevenebm's Avatar
stevenebm
post whore
speak english man.vertical plane?
Old Jun 16, 2009 | 07:34 PM
Garage19's Avatar
Garage19
I was going to say the same thing.
Old Jun 16, 2009 | 07:40 PM
stevenebm's Avatar
stevenebm
post whore
well give me some ideas.im all open.i have no idea what the vertical plane is
Old Jun 16, 2009 | 07:43 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I'd of made something to bolt onto the turbo from underneath onto the box, 2 rose joints, piece of ally round bar drilled and tapped? must be a bolt hole near the box that you can come off the manifold?
Old Jun 16, 2009 | 07:45 PM
Red16's Avatar
Red16
Old Jun 16, 2009 | 07:46 PM
stevenebm's Avatar
stevenebm
post whore
didnt want to come of the box as if a mount lets go it will take the manifold with it.well my thinking anyway.
Old Jun 16, 2009 | 07:50 PM
vroooom ptssssh
It Wasnt Me!
If a mount goes, the engine/box/manifold/exhaust will move with it Steve!
It's no more likely to go by just bracing the turbo to the box, easiest way to do it IMO, IF there is a bolt to come off on the box, which im sure there would be!
Old Jun 16, 2009 | 08:05 PM
stevenebm's Avatar
stevenebm
post whore
right so if i were to put a bar across where itl bolt on the rocker cover.then a triangle up the way and from the point of this triangle take it down to meet the two ends at the rose joints??
vrooommm tshh i dd have a look around at hole on the box but it was doing my head in trying to get sizes when the turbo was bolted on as its really tight under it.its really easy with the turbo on and working above it.your point is taking on board tho mate.
Old Jun 16, 2009 | 08:15 PM
Red16's Avatar
Red16
I'd be tempted to make it like one of these, pretty simple to do too
Old Jun 16, 2009 | 08:21 PM
Garage19's Avatar
Garage19
I recognise that last one!
Old Jun 16, 2009 | 08:24 PM
vroooom ptssssh
It Wasnt Me!
Steve, I know what you mean cant be a lot of room between the 2, Im sure what you've got will be fine!
Old Jun 16, 2009 | 09:37 PM
stevenebm's Avatar
stevenebm
post whore
cheers guys some good ideas there.will have a play around with a few tonight and tac a few things up and put some more pics up toomorow.thanks
Old Jun 16, 2009 | 10:03 PM
Miller 3's Avatar
Miller 3
heres the one i made
Old Jun 17, 2009 | 01:56 PM
stevenebm's Avatar
stevenebm
post whore
well had a busy nite at work.plus the welder wasnt in so done it all myself and it came out not too bad.the back leg is just for show.i need to weld in the proper one tonight at work but i need to take my rocker cover with me to get it spot on.there is now three mounting points.bolted it up this morning using the two and it was spot on so will be even better when the third is on and bolted down
Old Jun 18, 2009 | 09:46 PM
stevenebm's Avatar
stevenebm
post whore
finished and in the bay.pleased with it as it saved me a good bit of cashreally sturdy aswell.
Old Jun 18, 2009 | 09:52 PM
carlo's Avatar
carlo
Top job mate
Old Jun 18, 2009 | 10:02 PM
rst in breaking's Avatar
rst in breaking
good going, i have to make another one soon if i do carry on with me motor and fit the getrag box lol
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
IAN RS2k
Aug 18, 2015 07:51 PM
A.t.p
Aug 15, 2015 11:37 AM
muz
Aug 1, 2015 06:48 AM
