Inlet port sizes for 600 bhp on cossie head??
Old Jun 11, 2009 | 08:21 AM
Garage19's Avatar
Garage19
Default Inlet port sizes for 600 bhp on cossie head??
Im interested in a bit of info on cossie heads.
From what i seem to remember when i measured them stock cossie inlet ports are 24 x 48? mm at the gasket face.
What size would you expect to see on a head destined for a 5-600bhp car? Would the valves be increased in size?
Old Jun 11, 2009 | 08:45 AM
Turner RS's Avatar
Turner RS
25mm in 26mm out imo.
Old Jun 11, 2009 | 10:03 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
You will get the wrong answer asking that question its the biggest error that Tuners make getting port sizes wrong.
Best to say my valves are standard & port sizes not bigger than the ones quoted above & that made 838bhp so be warned go to someone who knows what its all about not the average punter on here.
Old Jun 11, 2009 | 10:08 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I dont believe there is a right or wrong answer, it all depends on the rest of the spec.
As rod mentions, he is getting massively more power than that on what most people would consider a fairly small head, but then he has a MASSIVE turbo.
Trying to get 600bhp out of a 600bhp turbo will probably require bigger ports than trying to get 838bhp out of a 900bhp turbo etc.
I agree with Rod that its easy to get carried away though, especially when selling things to people as people want to "see" the difference when they buy a head.
Old Jun 11, 2009 | 10:49 AM
PGT's Avatar
PGT
i recall a post by Karl some time ago where he stated that his std 500bhp head had standard sized holes at the head faces
Old Jun 11, 2009 | 11:47 AM
Garage19's Avatar
Garage19
Thats interesting. I was looking at some er, interesting porting the other day and the ports were 30.5 mm at the gasket face!
Old Jun 11, 2009 | 04:06 PM
Mark Shead's Avatar
Mark Shead
Chip
Mad ades head size is the same as Rods and guess what it makes on a 600hp turbo.
Mark
Old Jun 11, 2009 | 04:27 PM
Chip's Avatar
Chip
What turbo is Mad Ade on then, I though it was a GT35R capable of well over 600bhp on the right application?
Old Jun 11, 2009 | 04:43 PM
Mark Shead's Avatar
Mark Shead
Yes it is and its well over 600hp so it shows the ports sizes are correct.
Mark
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
shortie
Aug 19, 2015 01:01 AM
IAN RS2k
Aug 18, 2015 07:51 PM
mattman1234
24
Aug 1, 2015 11:46 AM
