F**k it! I'm going EFI and Megasquirt!!
Old Jun 10, 2009 | 03:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default F**k it! I'm going EFI and Megasquirt!!
There really is sooo much to be gained from going EFI..... economy, drivability, reliability, response, power, I think it has to be done!
My budget is tight but with selling a few of my old MFI parts and some other shit I have laying around I should just be able to muster the funds for EFI running Megasquirt!
I've landed a EFI inlet manifold, throttle body, injector rail (with blues), FPR, ICV, TPS, and injector loom for £85, EFI to MFI head conversion plate for £36, and will probably be buying Megasquirt II MS2-Extra v3.57 from http://www.extraefi.co.uk/ms2_products.htm for £360 including loom, data cable, software etc... unless I can find the same cheaper else where! So all in around the £500 mark give or take a bit, will of course need some beiges, a trigger wheel, VR sensor, and a pipe to go from the fuel filter to the rail!
I'll be fitting it myself, and Garage19 has very kindly offered to help me with the mapping!
Hopefully all will be done within the next 4 weeks!
Old Jun 10, 2009 | 03:49 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Might have an EFi throttle body knocking about if you need it bud?
Old Jun 10, 2009 | 03:53 PM
morph's Avatar
morph
I've landed a EFI inlet manifold, injector rail (with blues), FPR, ICV, TPS, and injector loom for £85, EFI to MFI head conversion plate for £36, and will probably be buying Megasquirt II MS2-Extra v3.57 from http://www.extraefi.co.uk/ms2_products.htm for £360 including loom, data cable, software etc... unless I can find the same cheaper else where!
mate you are 1 step nearer to reaching perfection once you bin that shite mfi!
can't believe there are people still thinking that mfi is good! once you start having issues its a f'ing nightmare!
Pm me i can get you a better setup all fitted, supplied and mapped not much more than what it will cost you. plus run a closed lopp lambda setup aswell as it will fuel like a modern day car.
Old Jun 10, 2009 | 03:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Oh forgot to mention I had that too! Cheers though!
Old Jun 10, 2009 | 03:55 PM
B1G_RST's Avatar
B1G_RST
ive got 308cc injectors here too,, as the blues are good for a small monkey bike, also why go megasquirt? will you not only be running around a bar with your bottom end ? if so will efi ofab not do you fine? save bit cash? not asking just because i have full convertion for sale honest lol,
Old Jun 10, 2009 | 04:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Are 308cc's Beige's? If so how much do you want for them? I'm not up on EFI injector sizes
MS for my budget, and it can be live mapped where as OFAB/OFAC is limited to what chip you can buy off the shelf so to speak, also I'm really keen to learn basic mapping myself!!
My bottom end is good for 220bhp to 250bhp like all stock RS bottom ends, what boost i'll be running is a result of my engines VE and target BHP so I dont know yet!
Old Jun 10, 2009 | 04:07 PM
orionmojo's Avatar
orionmojo
i have an efi flywheel if you want that. it owes me £12 plus postage if your interested.
you already have the rest of the efi stuff i have - but if you havent i've got an inlet, fuel rail, throttle body and flywheel i would sell you for £60 plus postage. i really need some cash.
Old Jun 10, 2009 | 04:08 PM
Marts's Avatar
Marts
So you finally gave into the temptation eh?!
Again, we all know ya gonna get it done properly mate, so good luck with it - and finally reaching a goal with your RS
Old Jun 10, 2009 | 04:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol I hope so Marts!
Old Jun 10, 2009 | 04:13 PM
B1G_RST's Avatar
B1G_RST
there bigger than beiges,
701s =226CC @ 3BAR 15.8 OHMS
IW-031 =275CC @ 3BAR 16.9 OHMS
785 =308cc @ 3BAR 14.2 OHMS
£100 deliverd
i always thot you neede rods/pistons over a bar,, ?
Old Jun 10, 2009 | 04:15 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Karlos m8 - start a rebuild thread on what you gonna do with step by step instructions as really interested in going down this route too especially if i can do it at same costs as yourself!
Good luck m8!
Old Jun 10, 2009 | 04:19 PM
grsford's Avatar
grsford
why not go for standard cossie injectors there cheaper
Old Jun 10, 2009 | 04:24 PM
B1G_RST's Avatar
B1G_RST
cant fit them if using ofab/ofac not sure about ms
Old Jun 10, 2009 | 04:25 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
VXR injectors are 475cc or so and only about 70 quid a set new.
Old Jun 10, 2009 | 04:27 PM
B1G_RST's Avatar
B1G_RST
they fit on ofab fuel rail and injector loom ? might use them when i get mines on gotech
Old Jun 10, 2009 | 04:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Really?? As above will they fit in a Fiesta EFI Rail/manifold?
In fact... what injectors will fit? Cossie as GRS said? What else? Bang for Buck is priority here!
Old Jun 10, 2009 | 04:32 PM
Chip's Avatar
Chip
Same fitment as cossie ones.
RST IN PROGRESS has them on his
Old Jun 10, 2009 | 04:33 PM
Robs Frst's Avatar
Robs Frst
I cant express how much you will enjoy EFI, More reliable, Power delivery better just feels a modern car.
MFi is horrible especially when things start going wrong.
Old Jun 10, 2009 | 04:35 PM
Barny's Avatar
Barny
seeing as people are trying to sell you bits i have a megasquirt ecu for sale too.
£250 posted
No loom with it tho, unless you want to stick it on a zetec lol
Old Jun 10, 2009 | 04:36 PM
crazycage's Avatar
crazycage
yes they fit fine and good for over 350hp.
Old Jun 10, 2009 | 04:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Good luck m8!
Should only be a day's work for me mate hardly worth a thread but i'll take some pics as i do it for you!
Sweet!
Cheers!
£250 posted
LOL What version? As i'm paying out I only really want the latest one v3.57 or v3.0
Excellent! Cheers!
Old Jun 10, 2009 | 04:47 PM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
ive got a fully rebuilt efi head with inlet if any is intrested getting hard to find now
Old Jun 10, 2009 | 04:48 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
sweet, ive got the V3 new ECU, cant wait to fit it, doug(garage19) knows his shit with megasquirt
Old Jun 10, 2009 | 04:52 PM
CombatSapph's Avatar
CombatSapph
I've megasquirted my Pinto with GXSR throttle bodies and mapped it myself.
It's an awesome experience if a little frustrating at times. I;m sure you'll enjoy the experience immesnely.
Give me a shout if I can be of any assiastance (pm me, I have a habit of losing topics I've replied to!).
Old Jun 10, 2009 | 04:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thanks mate but got a nice shiny new NMS head here already!
Yeah Jonnie was saying! You got it for a good price too didnt ya?
Thanks very much mate!
Old Jun 10, 2009 | 05:05 PM
JesseT's Avatar
JesseT
Flywheel:
Get the flywheel and forget abou thte trigger wheels. You'll be happy in the end. It really is one of the only "fit and forget" options. Zero possiblity for things to go wrong or need tuning.
Injectors:
Don't over size to your needs or just get the first ones you get hold of. 475cc/min is quite a lot for a 1.6cc engine unless you go over 300bhp. Cossie's 311cc/min is on the low side plus usually 15 years olds.
Old Jun 10, 2009 | 05:11 PM
orion_crazy_carl
orion=mini saff
yeah basicly free as i was fooked about so much, but he came good in the end
let me know when u go see doug, i need to drop some bits off to him so be a good excuse,lol
Old Jun 10, 2009 | 05:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Originally Posted by JesseT
Flywheel:
Injectors:
Yeah but pain in the arse to fit! Gearbox out and then a air gun to crack the bolts off!
So 311cc to small, 475cc to big, what do you recommend? Surely if I use 475cc the injector duty will just be quite small, is that a problem? In fact how can cossie ones be too small?? They run on a 2.0L producing what... 220bhp out the factory?
Bonus!!!
I've got to give Doug a bell and pop up to see him one saturday, so he can go through a few things with me so i'll let you know mate!
Old Jun 10, 2009 | 06:02 PM
orion_crazy_carl
orion=mini saff
sweet!i got a bottom cover as well if u need one!
Old Jun 10, 2009 | 06:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Bought one last night! Cheers though Carl
Old Jun 10, 2009 | 06:13 PM
mike s2 rst's Avatar
mike s2 rst
iv been looking into efi and have been getting results of about a grand just for bits!!!
Old Jun 10, 2009 | 06:28 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
It's not all bright on the other side, I jus converted to EFI and cant get a spark for love nor money
Old Jun 10, 2009 | 07:11 PM
mike s2 rst
iv been looking at gotech is megasquirt the same thing just another make??
Old Jun 10, 2009 | 07:20 PM
Garage19's Avatar
Garage19
I have also used them on two ZTs.
Old Jun 10, 2009 | 07:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Astra VXR injectors Doug? Not Corsa, or Vectra?
Then your not looking in the right places my friend!
lol There is always something!
Old Jun 10, 2009 | 07:40 PM
Garage19's Avatar
Garage19
Yeah, Astra vxr. Try Chris Astley Motorsport. Its where i have got them from in the past.
Old Jun 10, 2009 | 07:53 PM
Marts's Avatar
Marts
If you convert yours and have it started and running in one day Karlos, you can do mine the next day
I might go down this route one day, but knowing my funds and luck of late, that day will be a long way away!
Get the pics as a step by step innit... That'd help loads of people out
Old Jun 10, 2009 | 08:04 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
dont no if you are intrested but ive got a sierra 1.8 cvh bottom pully alt and the bracket? (its got a trigger wheel built in)
Old Jun 10, 2009 | 08:16 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
keep us updated karlos
Old Jun 10, 2009 | 08:19 PM
T28 RST's Avatar
T28 RST
Ok then
Will be interesting to see what results it produces
