Cosworth altenator position
Old Jun 10, 2009 | 12:31 PM
mk3cosworth's Avatar
mk3cosworth
Default Cosworth altenator position
Has anyone put there altenator on the oposite side were the power steering pump is
anyone got any suggestions
Old Jun 10, 2009 | 12:36 PM
GUZZLER's Avatar
GUZZLER
the 4x4 saff had something on the other side, think ot was the p/s pump though
Old Jun 10, 2009 | 12:43 PM
mk3cosworth
ye thats coming off and i have the blank for the block, i havnt tried any brackets up yet
Old Jun 11, 2009 | 09:35 PM
mk3cosworth
anyone
Old Jun 11, 2009 | 09:39 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
air con is mounted that side, the factory mounts for that may help you out...
the later model ps was mounted under the alternator on multigroove belt type
Old Jun 11, 2009 | 09:47 PM
jacko's Avatar
jacko
this has been done on a greek escos drag car
Old Jun 11, 2009 | 09:58 PM
mk3cosworth
ye ive seen that but couldnt see much of what he`s done
Old Jun 11, 2009 | 10:02 PM
jacko's Avatar
jacko
prob a case of just maker up a braket
use one of the other engines that is out of the car so its esier
Old Jun 11, 2009 | 10:42 PM
mk3cosworth
ye thats my plan just looking for ideas
Old Jun 12, 2009 | 12:43 AM
polly_x's Avatar
polly_x
Ive done 2 now mate for both Mine and Lees Westy Kit cars. One using a standard Cossie alternator and one a very small Denso one. Denso one needed a new pully and I got a fancy adjuster bar from a friend who had some laser cut.
Really easy using the power steering pump mount bolts on the inlet side.
Made the brackets and fitted new adjuster brackets underneath.
Only watchout is you have to keep it really low which means the angle of the belt causes it to rub on the crank sensor. Easy small mod to that though sorts this problem.
Stu
Old Jun 12, 2009 | 01:36 PM
mk3cosworth
cheers stu when i get round to do it, i might pm you
Old Jul 8, 2009 | 11:34 PM
mk3cosworth
Stu
dont supose you have any pics, im making a start on mine now
Old Jul 8, 2009 | 11:46 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
I'm interested in this aswell Wenny
Quick photo Stu sent me a while back when he was dong the conversion.
Hopefully he will supply us with a finished in situ pic
Old Jul 9, 2009 | 10:23 AM
polly_x's Avatar
polly_x
Funny you asked I was looking and moving some pics off my phone last night!
Not sure if you guys are still running power steering as I used the mount holes on the block that the PS bracket usually goes into.
Basically the alternator hangs upside down from its main mounts and the adjuster bar is fixed to the bottom of the new mount (if that makes sense)
Old Jul 9, 2009 | 12:10 PM
WD Pro's Avatar
WD Pro
Nice bracket
Old Jul 9, 2009 | 01:08 PM
polly_x's Avatar
polly_x
Originally Posted by WD Pro
Nice bracket
See above!
Stu
Nice adjuster bracket yes and supplied by Pete (WD Pro) too!......TOP GEEZER!
Old Jul 9, 2009 | 01:39 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Why would you want to remove the power steering to put an alternator in its place?
Old Jul 9, 2009 | 02:02 PM
polly_x's Avatar
polly_x
What power steering?
Old Jul 9, 2009 | 02:07 PM
CossieRich's Avatar
CossieRich
the thread starter said has anyone put an alternator where the power steering pump is. So i want to know why you would want to do that?
Old Jul 9, 2009 | 02:29 PM
The Youth.'s Avatar
The Youth.
to make the car lighter and to stop the alternator overheating as is the case now.
steve
Old Jul 9, 2009 | 02:49 PM
paul16v's Avatar
paul16v
Monte 087
Rich the alternator is suffering badly from heat from the turbo hence him wanting to move it to the other side of the engine as he is doing away with the power steering setup.
Old Jul 9, 2009 | 03:41 PM
CossieRich's Avatar
CossieRich
Would an alternator drop bracket not help with the heat issue or has that already been done?
Old Jul 9, 2009 | 03:56 PM
xr4x4rs's Avatar
xr4x4rs
the 4wd p/s pump is under the alternator turbo side, so tou can put the alternator where the air con pump would sit or where a 2wd p/s pump would sit and still remain p/s as its still on its original postion
but i think hes removing p/s anyhow
Old Jul 9, 2009 | 04:03 PM
paul16v's Avatar
paul16v
Monte 087
The setup on his engine is basically a full 2wd setup, alternator on turbo side of engine and p/s pump the other side.
Old Jul 9, 2009 | 08:51 PM
mk3cosworth
ye doing away with power steering and putting altenator on the colder side as paul16v says, if i find the steering to heavy ill put a corsa c elec pump on column
does anyone have a air con pump mounting bracket as thats under the inlet isnt it
Old Jul 9, 2009 | 08:59 PM
Kevin Sharp's Avatar
Kevin Sharp
if you have a full 2wd setup why not have an rs500 drop bracket made to drop alternator even further i had one made for my old escos to drop the alternator 20mm lower than it sat on a 500
never had any alternator issues due to heat on mine and by fook it got a hard time
Old Jul 9, 2009 | 09:01 PM
The Youth.'s Avatar
The Youth.
wenny you might want to make your own bracket as the air con one is cast and weighs about half a ton!
steve
Old Jul 9, 2009 | 11:04 PM
mk3cosworth
ye was thinking that steve but was going to use that as a base to work from, might just make 1 from scratch
kev it has the lower one on but its done 2 alts lately, so with the p/s coming off im going to put it over that side
Old Jul 11, 2009 | 09:10 PM
mk3cosworth
anyone wanting to do this, ive found a easy way to do it, us the base part of a 2wd power steering pump bracket, upside down with the block blank bolted back on, job done with a spacer on the long altenator bolt
Old Jul 11, 2009 | 10:22 PM
JTECH James
Passion for Fords!
if your not using power steering, i think the p100 rack is the one to use
Old Jul 11, 2009 | 10:48 PM
mk3cosworth
ye j i heard that, is it a quick rack compred to a normal non p/s rack and do they mount the same
Old Jul 11, 2009 | 10:54 PM
JTECH James
Passion for Fords!
i think its a similar ratio to the cossie rack mate, pretty sure they mount the same, get some funky billet bushes while your there!
Old Jul 11, 2009 | 10:57 PM
mk3cosworth
there allready in mate, with rose joint track rod ends
Old Jul 11, 2009 | 10:58 PM
scoooby slayer's Avatar
scoooby slayer
had a drop bracket on my cos but it still cooked alternators, 3 in 4500 miles
good idea mate
Old Jul 11, 2009 | 10:59 PM
JTECH James
Passion for Fords!
cool!
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
