suspension koni+apex? what you think?
hello
I have apex sport kit,lowering 40mm,but i have problems whith this shocks, what you think about fit koni sport + apex -40mm springs?
or is better fit koni sport KIT -25mm?
regards
regards
well on the koni website,it says the shocks can only take maximum of -35mm springs and thats cause of the ridges on the side of the shock.
i wanna go low with my s2,so am getting spax shortened shocks + cobra -50 springs with 16" alloys
[quote=jamieRST;4200461]well on the koni website,it says the shocks can only take maximum of -35mm springs and thats cause of the ridges on the side of the shock.
[/quote
WHY
25mm lowered was more than fine to get it lowered, it sat fine and handled perfect.
Anymore than that and you will ruin the cars handling.
WHY
m8 there will be a massive gap between the arch an the 16" wheel on -25mm.am getting adjustable track control arms,with a quaife atb diff,have got powerflex bushes so handling should be fine??
well mines lowered 60mm at the front and about 80 at the back and i eat through shocks like they're made of plastic. they go sponget in a few months and get completly knackered after about 10 months. i'm on my third set in as many years. its expensive
i cant bring myself to put it higher though
i had a set of spax and -40mm springs before and the handling was immense
the handling at -60mm is on par with stock if your generous.
SMILER258
Sep 28, 2015 09:04 AM
