Focus ABS
Old Jun 9, 2009 | 05:09 PM
daviddunlop83's Avatar
daviddunlop83
Default Focus ABS
I ordered a new drum and ABS sensor ring for a 1.6 focus with rear drums.
The old ring has teeth on it but the new one is like picture below.
Is this just a new design of the sensor ring or is this the incorrect abs ring?
Thanks
Old Jun 9, 2009 | 05:54 PM
B19 JUB's Avatar
B19 JUB
looks like a mk6 fiesta one tbh fella.try wiping the orig ring, it maybe just deposit build up making i look like teeth
Old Jun 9, 2009 | 06:08 PM
.Ross.'s Avatar
.Ross.
Aye .. Thats a Focus rear Disc Hub Magnetic Collector ring. You want the smaller Toothed Ring .. See if I have the Fin number for that somewhere.
Old Jun 9, 2009 | 06:13 PM
.Ross.'s Avatar
.Ross.
FIN Part # 7314843 ... Thats for an Escort MK6 ABS drum collector ring but iam sure they are the same ..
Old Jun 9, 2009 | 09:09 PM
James998's Avatar
James998
Are you sure its not just magnetic bits sticking to it making it appear like its got teeth?
Old Jun 9, 2009 | 09:31 PM
.Ross.'s Avatar
.Ross.
This is the Toothed ring ... Defo tell the difference .. This ring is also App'y for fiesta's
Old Jun 9, 2009 | 09:34 PM
daviddunlop83
Is the ring itself actually smaller im diameter as the ring in the picture fits onto the drum fine but the one that is on the original drum has teeth like the one in the last picture.
Old Jun 9, 2009 | 09:37 PM
daviddunlop83
What is the hub pictures off?
If possible could you measure the internal diameter of the ring?
Old Jun 9, 2009 | 09:38 PM
daviddunlop83
I was given the following finish number for it:-
Focus, (+)"GB", 1.6L Zetec-S EFI (100PS),3 Door Saloon, RHD
-Lockwasher Tooth Sensor
Part Number: 4664143
the vechile vin is:- WFOBXXGCDB3S10400 if anyone could check the number with that?
Thanks
Old Jun 9, 2009 | 09:41 PM
.Ross.'s Avatar
.Ross.
All I know is the Rear Disc HUB Mag Collector will be 72mm ID ...
What FINS have you got?
BTW Why cant you use the original Collector?
Old Jun 9, 2009 | 09:45 PM
daviddunlop83
The finis number for the one i got is :- 4664143
The reason i need a new one is that the guy who did a wheel bearing for him before decided to replace one drum and just not bother putting the sensor ring or the other spacer thing in at all and just put the drum on.
So i put the ring picture in and it didnt fix the problem
Ill measure the size of the one i have now and the drum also
Old Jun 9, 2009 | 09:47 PM
.Ross.'s Avatar
.Ross.
The HUB's a Focus 2.0 .... 72mm OD ... The ring is from an escort and it 66(ish)mm.
Old Jun 9, 2009 | 09:51 PM
daviddunlop83
The dia of the drum i have is 72 so the sensor ring for the escort wont fit?
The ring in the first picture fits perfect but the one on the other side that hasnt been tocuhed looked like the tooth ring in the second picture
Old Jun 9, 2009 | 09:54 PM
.Ross.'s Avatar
.Ross.
[quote=daviddunlop83;4200237]The dia of the drum i have is 72 so the sensor ring for the escort wont fit?
Strange that ... Whats the pick up like? Plastic? ... I couldnt get a Toothed ring of 72mm thats why I had to machined the hub for the 66mm ring ..
Gonna have to go to Ford dealer and have it out with them till you get sorted .. Good luck mate ..
Old Jun 9, 2009 | 09:57 PM
daviddunlop83
Yeah i ordered it from ford parts but i was hoping to get it all fitted on thurs, that wont be happening.
Think i will have to remove the toothed one and take the new one and the old one into ford and ask whats happening. It could be that the one i have got it a new design of the old ring or something.
Which means something else is wrong with the abs
Old Jun 9, 2009 | 09:59 PM
.Ross.'s Avatar
.Ross.
Good Idea mate ... I had the same problem .. They said it was an Updated version but I told em to get the right Collector ..
Have to go to the parts counter and get an experienced Parts man to help you out.
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
155lee
Sep 23, 2015 01:27 PM
cossiestu
Sep 19, 2015 05:19 AM
