leak down?
Old Jun 9, 2009 | 02:32 PM
coachworz's Avatar
coachworz
Default leak down?
what does cylinder leak down mean? and how does that happen?
Old Jun 9, 2009 | 04:06 PM
It's just compressed air is fed into a cylinder, and the amount of time it takes for the pressure to subside is measured, can give a lot better indication of some conditions than a std compy test.
Old Jun 10, 2009 | 01:04 AM
coachworz's Avatar
coachworz
mine got 50% leak down on 2,3,and4 cylinder!
Old Jun 10, 2009 | 08:52 AM
cossie604's Avatar
cossie604
The great thing about doing a leak down test is you can pin point the fault ie rings, inlet/exhaust valves or headgasket with out dismantling the engine...unlike a standard compression test that basicaly just tells you its down.
Old Jun 10, 2009 | 05:44 PM
kirky's Avatar
kirky
what tool do you use to do this test as i would like to do mine???
Old Jun 10, 2009 | 08:55 PM
cossie604's Avatar
cossie604
Mines a proper snap-on set up with a gauge. You can buy cheap versions that do exactly the same for around 30-40quid......but tbh you can make one also. Get an airline adaptor, a old spark plug and a peice of metal pipe. Smash the plug electrode out so you've just got a threaded part with a hole straight through. Weld the metal pipe to this then weld the airline adaptor on the end....just so you can fill the cylinder with compressed air. Set the piston at tdc on the compression stroke, leave it in gear with the handbrake on and hook up the air line to the fitted adaptor. You wont have a gauge but you can listen/look for the leaks. Oil filler cap off or dip stick out to gauge ring blow-by, ear to exhaust tail pipe to listen for a leaky ex valve, ear to inlet for inlet valve and Ive even managed to find a headgasket failure in the past by air bubble's in the header tank.
Old Jun 11, 2009 | 08:11 AM
kirky's Avatar
kirky
is this the gauge to use???
http://buy1.snapon.com/products/diag...s/eepv309a.asp
Old Jun 11, 2009 | 08:20 AM
cossie604's Avatar
cossie604
Nothing like mine but yeah, thats what your after.
Old Jun 11, 2009 | 08:24 AM
cossie604's Avatar
cossie604
Just looked on ebay and the cheapies are around Ł60....I think I must have sold my old spare one for around Ł30, hence where I got that price from in my head.
There's this one....
http://cgi.ebay.co.uk/Sykes-Pickavan...3A1%7C294%3A50
Old Jun 11, 2009 | 08:39 AM
kirky's Avatar
kirky
cheers for that!!!
Old Jun 11, 2009 | 09:04 AM
fraser9764's Avatar
fraser9764
i made one using the above method, apart from i tapped a 1/4 bsp thread into the remains of the spark plug and wound in a barrel nipple and make some adapters up to take an air line. worked perfectly for me, one completely fooked head
timsrs
Nov 13, 2018 11:48 AM
Fudgey
21
Sep 30, 2015 06:19 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
