Focus TD Di Problem
Old Jun 7, 2009 | 12:51 PM
PeterLucas's Avatar
PeterLucas
Default Focus TD Di Problem
Help please guys, trying to diagnose this one from a distance at the moment (havnt seen the car) but from what ive been told
1999 focus 1.8 TD Di Smokes when cold and runs rough ish (prob on three) but seems to clear when warm (not fully)
Has had -
Head , injectors, egr, filter !
Would a coolant temp sensor affect fueling drastically on this engine?
Any ideas?
Thanks in advance.
Old Jun 7, 2009 | 03:45 PM
PeterLucas's Avatar
PeterLucas
Anyone
Old Jun 7, 2009 | 03:57 PM
simon170's Avatar
simon170
I've just looked round the FFOC for you. The FIEona interface, the box that sits on top of the pump can cause problems. Its the interface between the Ford EECIV ECU and the Bosch VP30 pump.
Old Jun 7, 2009 | 04:03 PM
PeterLucas's Avatar
PeterLucas
Ah ok, thank you very much for that, guessing theres advancement control on the pump then?
Old Jun 7, 2009 | 10:19 PM
PeterLucas's Avatar
PeterLucas
Ok, looked at the car and could swear it was injectors weaping (although its had a second hand set!).
Cold it starts rough, and smokes diesel, run it and it clears and runs (puffs a bit of smoke).
Whats the best way of testing injectors? I was thinking of whipping ouut the injectors tomorow morning and cranking it over to see if any diesel spits out.
Old Jun 7, 2009 | 10:34 PM
as355f1's Avatar
as355f1
do a leak off test
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
